| earossi |
Oct 2 2014, 05:09 PM
Member ![]() ![]() Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
I need to replace the wire cable and its sheath that operates the front trunk hood. Is there an "easy" way to do this? Any pitfalls? Better yet, is there a DIY writeup out there. I used the Search feature but nothing turned up.
| HalfMoon |
Oct 2 2014, 08:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
No one's told you the fun part.
Getting it adjusted so it will reliably open the damn thing is an experience you will not want to do EVER again in this lifetime or the next. Don't ask how I know. In fact after many many attempts I took the stoopid thing off and pinned it. |
earossi Front Hood Lock Cable Release Replacement Oct 2 2014, 05:09 PM
r_towle I believe it is a tube that could be replaced with... Oct 2 2014, 05:20 PM
earossi
I believe it is a tube that could be replaced wit... Oct 2 2014, 06:34 PM
Johny Blackstain If you're not going to replace with stock part... Oct 2 2014, 05:42 PM
hndyhrr If you can find it long enough from a bike shop I ... Oct 2 2014, 06:19 PM
r_towle The cable needs to be in a Boleyn, or sheath yes, ... Oct 2 2014, 06:27 PM
Johny Blackstain
The cable needs to be in a Boleyn, or sheath yes,... Oct 2 2014, 06:31 PM
bdstone914 The end of the original cable has a threaded end t... Oct 2 2014, 06:35 PM
earossi So, the plastic sheathe is a length of plastic tub... Oct 2 2014, 06:42 PM
mepstein place a wtb in the classifieds and get a real repl... Oct 2 2014, 08:03 PM
Chris H. 914rubber sells the cable itself all set up correc... Oct 2 2014, 08:10 PM
earossi
914rubber sells the cable itself all set up corre... Oct 2 2014, 09:07 PM
[quote name='Chris H.' post='2093171' date='Oct 2... Oct 2 2014, 09:15 PM
earossi
[quote name='Chris H.' post='2093171' date='Oct ... Oct 2 2014, 10:59 PM
[quote name='mepstein' post='2093216' date='Oct 2... Oct 3 2014, 04:56 AM
Getting it ad... Oct 2 2014, 08:36 PM
jeffdon
Getting it a... Oct 2 2014, 08:38 PM
[quote name='mepstein' post='2093197' date='Oct 2... Oct 2 2014, 09:12 PM
earossi OK. I played with the car tonight and answered on... Oct 2 2014, 08:56 PM
jsh
I need to replace the wire cable and its sheath t... Oct 2 2014, 09:19 PM
Steve I just did mine also. Bought it all from Pelican.... Oct 2 2014, 09:26 PM
earossi OK. All done......and successfully! It was a... Oct 3 2014, 03:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:52 PM |
