> Front Hood Lock Cable Release Replacement, Is there a DIY available for replacement?
earossi
post Oct 2 2014, 05:09 PM
I need to replace the wire cable and its sheath that operates the front trunk hood. Is there an "easy" way to do this? Any pitfalls? Better yet, is there a DIY writeup out there. I used the Search feature but nothing turned up.
HalfMoon
post Oct 2 2014, 08:31 PM
No one's told you the fun part.
Getting it adjusted so it will reliably open the damn thing is an experience you will not want to do EVER again in this lifetime or the next. Don't ask how I know.
In fact after many many attempts I took the stoopid thing off and pinned it.
post Oct 2 2014, 08:36 PM
914-6 GT in waiting
QUOTE(HalfMoon @ Oct 2 2014, 10:31 PM) *
I'm not sure why you had so much trouble. I took mine apart. Lubed the cable, latch and lock. Reassembled, and it works perfectly. Didn't require any real fiddling, just tightened everything down and worked. Cable pull is much easier once it's all lubed and puts way less stress on the cable and mechanism (which is pretty universal when cleaning and lubing almost all the moving parts on our cars).
earossi   Front Hood Lock Cable Release Replacement   Oct 2 2014, 05:09 PM
r_towle   I believe it is a tube that could be replaced with...   Oct 2 2014, 05:20 PM
earossi   I believe it is a tube that could be replaced wit...   Oct 2 2014, 06:34 PM
Johny Blackstain   If you're not going to replace with stock part...   Oct 2 2014, 05:42 PM
hndyhrr   If you can find it long enough from a bike shop I ...   Oct 2 2014, 06:19 PM
r_towle   The cable needs to be in a Boleyn, or sheath yes, ...   Oct 2 2014, 06:27 PM
Johny Blackstain   The cable needs to be in a Boleyn, or sheath yes,...   Oct 2 2014, 06:31 PM
bdstone914   The end of the original cable has a threaded end t...   Oct 2 2014, 06:35 PM
earossi   So, the plastic sheathe is a length of plastic tub...   Oct 2 2014, 06:42 PM
mepstein   place a wtb in the classifieds and get a real repl...   Oct 2 2014, 08:03 PM
Chris H.   914rubber sells the cable itself all set up correc...   Oct 2 2014, 08:10 PM
earossi   914rubber sells the cable itself all set up corre...   Oct 2 2014, 09:07 PM
mepstein   [quote name='Chris H.' post='2093171' date='Oct 2...   Oct 2 2014, 09:15 PM
earossi   [quote name='Chris H.' post='2093171' date='Oct ...   Oct 2 2014, 10:59 PM
mepstein   [quote name='mepstein' post='2093216' date='Oct 2...   Oct 3 2014, 04:56 AM
HalfMoon   No one's told you the fun part. Getting it adj...   Oct 2 2014, 08:31 PM
mepstein   No one's told you the fun part. Getting it ad...   Oct 2 2014, 08:36 PM
jeffdon   No one's told you the fun part. Getting it a...   Oct 2 2014, 08:38 PM
mepstein   [quote name='mepstein' post='2093197' date='Oct 2...   Oct 2 2014, 09:12 PM
earossi   OK. I played with the car tonight and answered on...   Oct 2 2014, 08:56 PM
jsh   I need to replace the wire cable and its sheath t...   Oct 2 2014, 09:19 PM
Steve   I just did mine also. Bought it all from Pelican....   Oct 2 2014, 09:26 PM
earossi   OK. All done......and successfully! It was a...   Oct 3 2014, 03:55 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:20 PM
