| jsaum |
Oct 2 2014, 11:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm trying to get everything working on my 72 914 including the fresh air blower and defroster control on the dash. I traced down the power going to the control selector lever for the three speeds, the red & white wire which does have 12 volts but it doesn't connect to anything! Am I missing a connector or a wiring harness that gets power to the blower motor from the dash? There isn't any bulbs or holders for the red and blue bezels on the control panel it seems like there should be more there!
Thanks for the help! Jsaum Attached thumbnail(s) |
| jsaum |
Oct 3 2014, 10:35 AM
OK thanks for all the great info it all makes sense now. I'll do some more checking on the connections and wires this weekend, looks like the gas tank will have to come out in the near future to get at the blower motor. What type of bulb is used for the connector in the dash?
Jsaum |
jsaum Ventilating System no blow! Oct 2 2014, 11:26 PM
AvalonFal I can tell you how a '74 works because I just ... Oct 3 2014, 07:07 AM
cary What you have in fingers is the indicator bulb hol... Oct 3 2014, 07:18 AM
BeatNavy I also JUST went through this on a '72. I agr... Oct 3 2014, 07:56 AM
Philip W. ive started the process of trying to get mine work... Oct 3 2014, 09:37 AM
AvalonFal
OK thanks for all the great info it all makes sen... Oct 3 2014, 10:39 AM
BeatNavy I tore into my '72 fan housing too look at the... Oct 3 2014, 05:25 PM
BeatNavy
I tore into my '72 fan housing too look at th... Oct 4 2014, 09:25 AM
jsaum Well I made some progress but no sucess in getting... Oct 3 2014, 09:56 PM
etcmss relay is on the main fuse panel.
http://bowlsby.ne... Oct 4 2014, 04:08 AM
jsaum Does anyone have a picture of the wiring harness f... Oct 4 2014, 12:08 PM
AvalonFal
Does anyone have a picture of the wiring harness ... Oct 4 2014, 01:23 PM
jsaum OK that explains why I can't find it! I ch... Oct 4 2014, 01:50 PM
etcmss attached wiring drawing for 72-73.
the lights ar... Oct 5 2014, 04:05 AM
jsaum
the lights a... Oct 9 2014, 02:33 PM
clapeza
[quote name='etcmss' post='2094145' date='Oct 5 2... Oct 9 2014, 03:27 PM
jsaum I made some progress at the fuse box figured out w... Oct 9 2014, 11:05 PM
Philip W. so (jsaum) what did you find out on this? was the ... Oct 31 2014, 09:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:33 PM |
