> 914-6 conversion question, what else do I need?
Mr_Chu
post Aug 21 2004, 04:53 PM
Ok, so I have a 914 and also a 911SC. I am going to throw in the 3.0-liter motor into my 914.
I have to change the oil tank, I have to do the ring and piston thing, motor mounts, heat exchangers and new oil lines and stuff. What else do I need to do?
I know I have to upgrade suspension and braking, but what else do I need in order to swap motors and tranmission? Do I need to modify anything else? I pretty much have all the pieces to do the conversion, the problem I'm having is actually starting!
Any comments, suggestions, or missing parts I might need to do the full swap?
This conversion is starting to be a nightmare and its also costing me a pretty penny! (IMG:style_emoticons/default/mad.gif) Any help would be greatly appreciated!
Also, thanks for the guys that gave me some pointers earlier. That really helped me out!
Mr_Chu
post Aug 22 2004, 05:27 PM
Hey guys I appreciate the help.
First of all I need to get a motor mount. Do I need a mount for my transmission as well? A costly 915 tranny rebuild seems to be in my future. (The r/p thing is confusing the hell out of me)
I also need the sheet metal. Will the 914-6 sheet metal kit be able to fit the 3.0 liter motor from my 911 sc? Cause afterall, the original 6 is a 2.0-liter motor.
And if I get a stock 914-6 oil tank.. will it fit right in between the fender and motor? Or do i have to cut and weld?
Heat exchangers is another thing i'm kind of confused about. Should i get the 914-6 heat exchangers? Will that bolt onto my SC motor or do I need to find some other kind of heat exchangers?
And one of you said something about a special flywheel? Can you clarify this for me.
As for the fuel injection thing, as much as I would like to convert my motor to carbs, I think that using the fuel injection system off of the SC engine would be the most easy way for me to do it. Or is it? I'm not too sure about this yet. But turning to Carbs is more money that I don't really have.
As for my cars, I really dont want to take apart everything just yet. Both my cars are runnning perfectly. I would actually like to collect all the necessary pieces before i actually start stripping. Afterall, two cars are easier to move around if they are together rather than moving 100 billion pieces!
I bought a whole 911SC for my conversion. In the beginning all I wanted was more of a punch to my 914. The cost of this is definitely racking up! So if any of you guys out there know of places that sell this kind of stuff at a good price.. please recommend!
Again, thanks to all the guys that responded!
Mr_Chu   914-6 conversion question   Aug 21 2004, 04:53 PM
seanery   shift rod. what year is the car?   Aug 21 2004, 05:10 PM
Mr_Chu   It's a 74 914... 2.0-liter.   Aug 21 2004, 08:04 PM
Mr_Chu   I can still use some advice.. <_<   Aug 22 2004, 12:46 AM
McMark   Your question is too broad. Looks like you have a...   Aug 22 2004, 01:08 AM
joea9146   You will need a clutch adapter kit. You can get it...   Aug 22 2004, 04:20 AM
seanery   why the clutch adapter kit? :confused:   Aug 22 2004, 09:28 AM
lylegd   1) The 3.0 liter motor will require use of a speci...   Aug 22 2004, 10:28 AM
!   ring and piston thing.... What's that? The 3...   Aug 22 2004, 10:45 AM
seanery   I still don't get the adapter kit. He has the...   Aug 22 2004, 11:44 AM
!   If he's using the 915 trnas....he needs to fli...   Aug 22 2004, 12:00 PM
seanery   I knew the R/P but 2 people said he needed an adap...   Aug 22 2004, 12:13 PM
McMark   He doesn't need an adapter. The transmission ...   Aug 22 2004, 01:09 PM
Mr_Chu   Hey guys I appreciate the help. First of all I ...   Aug 22 2004, 05:27 PM
McMark
  Aug 22 2004, 09:50 PM
jgiroux67     Aug 22 2004, 11:14 PM
Mr_Chu   thanks guys.. Do any of you guys know a good pla...   Aug 23 2004, 04:35 PM
!   As mentioned before.... GPR.. 800-321-5432 Rich Jo...   Aug 23 2004, 04:45 PM
ArtechnikA   you will also need to have the on-engine oil coole...   Aug 23 2004, 04:49 PM
seanery   Rich Clewett does the oil cooler conversion: Rich ...   Aug 23 2004, 05:22 PM
Cap'n Krusty   Gonna have to figure out a way to mount that 915 t...   Aug 23 2004, 05:36 PM
ArtechnikA     Aug 26 2004, 12:48 PM
Mr_Chu   hah.. well I already bought an engine. Well i ac...   Aug 27 2004, 05:20 PM
ArtechnikA     Aug 27 2004, 06:06 PM
Mr_Chu   ya "one man's junk is another man's treasu...   Aug 28 2004, 10:50 AM
- Lo-Fi Version Time is now: 20th September 2026 - 08:29 PM
