| jsaum |
Oct 2 2014, 11:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm trying to get everything working on my 72 914 including the fresh air blower and defroster control on the dash. I traced down the power going to the control selector lever for the three speeds, the red & white wire which does have 12 volts but it doesn't connect to anything! Am I missing a connector or a wiring harness that gets power to the blower motor from the dash? There isn't any bulbs or holders for the red and blue bezels on the control panel it seems like there should be more there!
Thanks for the help! Jsaum Attached thumbnail(s) |
| BeatNavy |
Oct 3 2014, 05:25 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
I tore into my '72 fan housing too look at the resistors and other connections. Here's a picture of the resistor springs. When I measure the resistance across each, I got something from 4K to 8K ohms (the multimeter bounced around).
Here are the corresponding 4 posts on the outside. One, I think the upper right, is the 12v input. The others are ground connections that connect from the climate control grounds in the dash through these resistors and to the ground connection at the actual blower motor. With the blower in the housing I was able to "bench test" it on the battery by connecting a 12v jumper to the upper right connection and then use a ground wire at the other connections. I found I had something like a slow speed when I grouned the right lower pole and a high speed when I grounded the lower left pole. Not sure how I was supposed to get a mid speed. Then I hooked it up to the connector under the hood. Here's where the fun started. I get a little smoke when I put the climate control selector on low, a LOT of smoke when I put it on mid speed, and good, solid blower action (and no smoke) on high. Obviously I'm shorting something to cause the smoke. I'm not sure what gives. Need to think this through some more. Smoke near the fuel tank is not an ideal feature. |
jsaum Ventilating System no blow! Oct 2 2014, 11:26 PM
AvalonFal I can tell you how a '74 works because I just ... Oct 3 2014, 07:07 AM
cary What you have in fingers is the indicator bulb hol... Oct 3 2014, 07:18 AM
BeatNavy I also JUST went through this on a '72. I agr... Oct 3 2014, 07:56 AM
Philip W. ive started the process of trying to get mine work... Oct 3 2014, 09:37 AM
jsaum OK thanks for all the great info it all makes sens... Oct 3 2014, 10:35 AM
AvalonFal
OK thanks for all the great info it all makes sen... Oct 3 2014, 10:39 AM
BeatNavy
I tore into my '72 fan housing too look at th... Oct 4 2014, 09:25 AM
jsaum Well I made some progress but no sucess in getting... Oct 3 2014, 09:56 PM
etcmss relay is on the main fuse panel.
http://bowlsby.ne... Oct 4 2014, 04:08 AM
jsaum Does anyone have a picture of the wiring harness f... Oct 4 2014, 12:08 PM
AvalonFal
Does anyone have a picture of the wiring harness ... Oct 4 2014, 01:23 PM
jsaum OK that explains why I can't find it! I ch... Oct 4 2014, 01:50 PM
etcmss attached wiring drawing for 72-73.
the lights ar... Oct 5 2014, 04:05 AM
jsaum
the lights a... Oct 9 2014, 02:33 PM
clapeza
[quote name='etcmss' post='2094145' date='Oct 5 2... Oct 9 2014, 03:27 PM
jsaum I made some progress at the fuse box figured out w... Oct 9 2014, 11:05 PM
Philip W. so (jsaum) what did you find out on this? was the ... Oct 31 2014, 09:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:33 PM |
