> a 912 e question about smogin california
rosenfe
post Oct 5 2014, 05:45 PM
i know its not a 914 but similar engine.im looking to buy one.owner had engine rebuilt 100 miles ago,nice car,but thermals are gone.he says that if it fails smog and ca. state bar cannot locate new thermasl,it gets a waiver.is this true and are new thermasl nla?.
i would prefer not put them on anyway.parts haven says nla.
veekry9
post Oct 6 2014, 03:03 AM
OldMember
Group: Retired Members
The ultimate in aircooled technology available today applied to the 60-70's products
would certainly improve the emissions count.
I haven't read of anyone adapting direct injection variable valve timing and modern cats to the engines.Running a late model liquid cooled h4-6 demands that the engines smog equipment is intact,right?The sniffer does a comparator curve fitting routine for the model of engine or vehicle or both?
Cap'n Krusty
post Oct 6 2014, 10:12 AM
Cap'n Krusty
QUOTE(veekry9 @ Oct 6 2014, 02:03 AM) *
Requirements state the emissions equipment be present for either the engine or the vehicle, whichever is NEWER. Drop a 2014 Subie motor in your car, it MUST have every bit of emissions related equipment present in the donor car when it was certified by the Air Resources Board. That can mean the instrument cluster, the wiring and electronics, and usually the transmission and it's electronics.
Drop an '83 911SC engine in it, you'll need all the emissions electronics and hardware, as well as an evap system compliant with '83 regulations. Not such a big deal.
My take on the 912e, based on some experience here in CA, is it'll pass w/o the thermal reactors, which all but the most stringent of smog tech will not even recognize. You will, however, need a functional air pump system, the stock air filter housing, and a lot of prayers that the airbox will allow you to get it lean enough to pass the tail pipe test. If the car has solid lifters, setting the valves to .016" for the test will drop the HCs immensely, and you should run the test only after filling the near-empty tank with the lowest octane fuel you can find.
Remember, the SELLER pays for and provides the smog certificate, and it's a responsibility he/she CANNOT abdicate, and the buyer cannot legally waive, unless the buyer is a dealer or dismantler.
Edit: Hmmm. I forgot to answer the above statement. You can provide "modern technological" answers for the emissions equipment and "numbers" in CA, but everything you do will have to be ARB approved as individual pieces AND as a whole, meaning you'll have to spend literally tens of thousands (and probably even hundreds of thousands) of dollars in the testing and approval processes necessary to gain that highly sought after ARB approval number.
The Cap'n
rosenfe   a 912 e question about smogin california   Oct 5 2014, 05:45 PM
jim_hoyland   Is the car currently registered in CA ? If so, the...   Oct 5 2014, 05:56 PM
rosenfe   Is the car currently registered in CA ? If so, th...   Oct 5 2014, 06:13 PM
mikesmith   In California it is the *seller's* responsibil...   Oct 5 2014, 06:17 PM
RobW   100% correct. Sellers responsibility. What year is...   Oct 5 2014, 06:27 PM
RobW   When I still had to smog the '74 I drove every...   Oct 5 2014, 06:29 PM
rosenfe   bar tag may be the way to go,especially as thermal...   Oct 5 2014, 06:47 PM
Joe Bob   76 912 E in CA? Runaway.......one year only with...   Oct 5 2014, 08:20 PM
veekry9   Certainly,a clause exists that allows the exceedin...   Oct 5 2014, 08:27 PM
Cuda911   ^^^ Nope. The retarded CARB left no such exemption...   Oct 5 2014, 09:21 PM
Mike Bellis   To get an exemption you must: 1) have ALL smog eq...   Oct 5 2014, 09:31 PM
Cap'n Krusty   Add to that, the car has to have failed and the mo...   Oct 5 2014, 09:36 PM
pete000   Smog pulley bracket and bearings are not replaceab...   Oct 5 2014, 10:36 PM
914Mike   Smog pulley bracket and bearings are not replacea...   Oct 5 2014, 10:55 PM
Maltese Falcon   ...and after you locate all of these items, instal...   Oct 5 2014, 10:51 PM
Elliot Cannon   The "buyer" is responsible for a smog ch...   Oct 5 2014, 11:36 PM
dlkawashima   The "buyer" is responsible for a smog c...   Oct 6 2014, 12:45 AM
jcd914   From "http://www.bar.ca.gov/Consumer/Referee/...   Oct 6 2014, 12:15 AM
veekry9   The ultimate in aircooled technology available tod...   Oct 6 2014, 03:03 AM
Cap'n Krusty   The ultimate in aircooled technology available to...   Oct 6 2014, 10:12 AM
rosenfe   i just spoke to ca state bar.they said:if car fail...   Oct 6 2014, 09:32 AM
Dave_Darling   ...if they cannot locate part i get a exemption.d...   Oct 6 2014, 12:12 PM
X911IC   i just spoke to ca state bar.they said:if car fai...   Oct 6 2014, 01:50 PM
Joe Bob   AND you have to do that dance every two years. Yo...   Oct 6 2014, 09:36 AM
396   AND you have to do that dance every two years. Y...   Oct 6 2014, 03:22 PM
Maltese Falcon   AND you have to do that dance every two years. Y...   Oct 6 2014, 07:40 PM
toolguy   In the Democratic Republic of California, there ar...   Oct 6 2014, 10:21 AM
Johny Blackstain   Wow, what a crock of :stromberg:   Oct 6 2014, 10:29 AM
rosenfe   ive been speaking with an unamed shop and there ar...   Oct 6 2014, 12:23 PM
rhodyguy   sounds like a big 'could be left hanging' ...   Oct 6 2014, 12:30 PM
rosenfe   gotta b brave with these old porsches.if all else ...   Oct 6 2014, 12:46 PM
Al Meredith   greetings from Georgia, I love my 912E . 2056, R...   Oct 6 2014, 01:17 PM
Drums66   greetings from Georgia, I love my 912E . 2056, Rab...   Oct 6 2014, 01:22 PM
sbsix   I've danced with CARB smogging a non-domestic ...   Oct 6 2014, 01:52 PM
McMark   I have heard it on VERY good authority that you ca...   Oct 6 2014, 04:11 PM
PancakePorsche   My 76 914 passes Ca smog by a country mile. You mu...   Oct 7 2014, 12:13 AM
Mikey914   My 912E will pass the Oregon DEQ without the react...   Oct 7 2014, 11:26 PM
RenoRoger   My 912E will pass the Oregon DEQ without the reac...   Oct 9 2014, 02:20 AM
rosenfe   i bought the car and drove about 120 miles home to...   Oct 18 2014, 07:56 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:13 AM
