| kpax914 |
Sep 10 2014, 01:20 AM
Newbie ![]() Group: Members Posts: 9 Joined: 10-July 14 From: Santee, CA Member No.: 17,610 Region Association: Southern California |
I have a 73, 1.7 liter with everything new or checks out OK on the Fuel Injection. One culprit left the CPU. I'm in El Cajon Area of San Diego. Any rebuilders, besides sending to PelicanParts?
| Chris Pincetich |
Oct 6 2014, 04:33 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I just replaced an ECU for my 1972 914 1.7 with D-jet. It wasn't sending the ground signal to the relay board and my fuel pump wouldn't run. Due to parts availability, I had a "022 906 021 B" ECU and now have a "022 906 021 E". Problem solved. Mine was running OK off the bad ECU with the fuel pump ground "jumpered" to a good ground wire. Thanks again to Capt Krusty, Tom, McMark, and bdstone for all their help! It took three weeks of testing almost everything before we concluded to swap the ECU.
Good luck (IMG:style_emoticons/default/beerchug.gif) |
| worn |
Oct 6 2014, 08:50 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,558 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I just replaced an ECU for my 1972 914 1.7 with D-jet. It wasn't sending the ground signal to the relay board and my fuel pump wouldn't run. Due to parts availability, I had a "022 906 021 B" ECU and now have a "022 906 021 E". Problem solved. Mine was running OK off the bad ECU with the fuel pump ground "jumpered" to a good ground wire. Thanks again to Capt Krusty, Tom, McMark, and bdstone for all their help! It took three weeks of testing almost everything before we concluded to swap the ECU. Good luck (IMG:style_emoticons/default/beerchug.gif) Were you able to identify the cause of the failure, or in all else send it to Jeff Bowelsby? I am figuring these little gems ought to be saved if possible. They are amazing transistor analogs of the fuel map of the engine. Like a bumblebee shouldn't oughta fy, but they do. |
kpax914 CPU Overhaul Sep 10 2014, 01:20 AM
76-914 Are you sure? Those are pretty much bullet proof i... Sep 10 2014, 08:09 AM
kpax914
Are you sure? Those are pretty much bullet proof ... Oct 5 2014, 08:17 PM
JamesM
...I have exhausted everything else that could be... Oct 6 2014, 10:53 PM
Chris Pincetich
If it starts and runs on all 4, but just runs bad... Oct 7 2014, 01:49 PM
kpax914
...I have exhausted everything else that could b... Oct 7 2014, 06:14 PM
SirAndy Are you sure? Those are pretty much bullet proof i... Oct 6 2014, 01:23 AM
boxsterfan Have you read this site?
http://members.rennlist.... Sep 10 2014, 09:14 AM
Cap'n Krusty That story is a bit suspect. In the 40 plus years... Oct 5 2014, 09:41 PM
Tom If it is running poorly at idle and more throttle ... Oct 6 2014, 12:41 AM
stugray
Anyway I hooked up the 2 CPUs and same dproblem w... Oct 6 2014, 08:19 AM
pilothyer I think you nailed your problem in your post #4 wh... Oct 6 2014, 08:35 AM
76-914 I have a spare MPS also if you want to check that.... Oct 6 2014, 08:40 AM
Dave_Darling I have seen two failure modes so far from the ECU.... Oct 6 2014, 12:17 PM
dknechtly I've had the same issue with the fuel pump not... Oct 6 2014, 01:02 PM
Johny Blackstain I seem to remember the ECU could also go bad if su... Oct 6 2014, 12:20 PM
Drums66 .....It does happen!(CPU failure)but............. Oct 6 2014, 01:15 PM
Jacob What do you see when you hook up the vacuum gauge?... Oct 6 2014, 01:46 PM
kpax914 Hello everybody:
It wasn't the CPU! But a ... Nov 12 2014, 12:31 AM
type47
[color=#FF0000]??
But a combo of vacuum leak a... Nov 12 2014, 09:03 AM
Racer Chris
[color=#FF0000]??
But a combo of vacuum leak ... Nov 12 2014, 09:09 AM
type47
cold start injector mounted on the plenum
OK, co... Nov 12 2014, 09:23 AM
76-914 AA, There across the country. West coasters usuall... Nov 12 2014, 08:29 AM
kpax914
AA, There across the country. West coasters usual... Nov 13 2014, 05:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 11:21 AM |
