> CPU Overhaul
kpax914
post Sep 10 2014, 01:20 AM
I have a 73, 1.7 liter with everything new or checks out OK on the Fuel Injection. One culprit left the CPU. I'm in El Cajon Area of San Diego. Any rebuilders, besides sending to PelicanParts?
post Sep 10 2014, 08:09 AM
Are you sure? Those are pretty much bullet proof in general. I'm in Temecula and will loan you one to confirm. It's off a 2.0 but should work to confirm or negate your supposition. If your not very well versed in 914's you might want to post up what problems your running into.
kpax914
post Oct 5 2014, 08:17 PM
QUOTE(76-914 @ Sep 10 2014, 07:09 AM) *
Thank you for your recommendo.
Yes I consult the site. Really first class and informative. I post because I have exhausted everything else that could be bad except the vacuum pressure sensor.
I might take you up on your offer. Because the local recycling place (Autobahn, in El Cajon) Let me hook up 2 CPUs that they have that are used. They cautioned me however about the similarity in malfuncton of CPUs. They sold one, which was defective and had to send a customer 3 more! Only one was good. Anyway I hooked up the 2 CPUs and same dproblem with the idle as mine. Advance the throttle and problem goes away.
Thankx
Kpax914
JamesM
post Oct 6 2014, 10:53 PM
QUOTE(kpax914 @ Oct 5 2014, 06:17 PM) *
...I have exhausted everything else that could be bad except the vacuum pressure sensor.
Its your pressure sensor then. They are about 1000x more likely to fail then the ecu.
If it starts and runs on all 4, but just runs badly, its most likely not the ECU
Failure of the diaphragm would mean the ECU already sees full load (or close to it depending on how bad it has failed), meaning that at idle/part load it would be super rich but under some throttle it would be closer to running correct.
Not going to guarantee anything though as idle issues can be quite a few different things, but it is unlikely the ECU is bad.
Chris Pincetich
post Oct 7 2014, 01:49 PM
B-)
QUOTE(JamesM @ Oct 6 2014, 09:53 PM) *
kpax914   CPU Overhaul   Sep 10 2014, 01:20 AM
76-914   Are you sure? Those are pretty much bullet proof i...   Sep 10 2014, 08:09 AM
kpax914   Are you sure? Those are pretty much bullet proof ...   Oct 5 2014, 08:17 PM
JamesM   ...I have exhausted everything else that could be...   Oct 6 2014, 10:53 PM
Chris Pincetich   If it starts and runs on all 4, but just runs bad...   Oct 7 2014, 01:49 PM
kpax914   ...I have exhausted everything else that could b...   Oct 7 2014, 06:14 PM
SirAndy   Are you sure? Those are pretty much bullet proof i...   Oct 6 2014, 01:23 AM
boxsterfan   Have you read this site? http://members.rennlist....   Sep 10 2014, 09:14 AM
Cap'n Krusty   That story is a bit suspect. In the 40 plus years...   Oct 5 2014, 09:41 PM
Tom   If it is running poorly at idle and more throttle ...   Oct 6 2014, 12:41 AM
stugray   Anyway I hooked up the 2 CPUs and same dproblem w...   Oct 6 2014, 08:19 AM
pilothyer   I think you nailed your problem in your post #4 wh...   Oct 6 2014, 08:35 AM
76-914   I have a spare MPS also if you want to check that....   Oct 6 2014, 08:40 AM
Dave_Darling   I have seen two failure modes so far from the ECU....   Oct 6 2014, 12:17 PM
dknechtly   I've had the same issue with the fuel pump not...   Oct 6 2014, 01:02 PM
Johny Blackstain   I seem to remember the ECU could also go bad if su...   Oct 6 2014, 12:20 PM
Drums66   .....It does happen!(CPU failure)but.............   Oct 6 2014, 01:15 PM
Jacob   What do you see when you hook up the vacuum gauge?...   Oct 6 2014, 01:46 PM
Chris Pincetich   I just replaced an ECU for my 1972 914 1.7 with D-...   Oct 6 2014, 04:33 PM
worn   I just replaced an ECU for my 1972 914 1.7 with D...   Oct 6 2014, 08:50 PM
kpax914   Hello everybody: It wasn't the CPU! But a ...   Nov 12 2014, 12:31 AM
type47   [color=#FF0000]?? But a combo of vacuum leak a...   Nov 12 2014, 09:03 AM
Racer Chris   [color=#FF0000]?? But a combo of vacuum leak ...   Nov 12 2014, 09:09 AM
type47   cold start injector mounted on the plenum OK, co...   Nov 12 2014, 09:23 AM
76-914   AA, There across the country. West coasters usuall...   Nov 12 2014, 08:29 AM
kpax914   AA, There across the country. West coasters usual...   Nov 13 2014, 05:31 PM
- Lo-Fi Version Time is now: 14th March 2026 - 11:18 AM
