> Ventilating System no blow!, What am I missing?
jsaum
post Oct 2 2014, 11:26 PM
I'm trying to get everything working on my 72 914 including the fresh air blower and defroster control on the dash. I traced down the power going to the control selector lever for the three speeds, the red & white wire which does have 12 volts but it doesn't connect to anything! Am I missing a connector or a wiring harness that gets power to the blower motor from the dash? There isn't any bulbs or holders for the red and blue bezels on the control panel it seems like there should be more there!
Thanks for the help!
Jsaum
etcmss
post Oct 5 2014, 04:05 AM
etcmss
attached wiring drawing for 72-73.
the lights aren't clear for left bulb and right bulb but appears to be 2 different ones.
Attached File(s)
jsaum
post Oct 9 2014, 02:33 PM
QUOTE(etcmss @ Oct 5 2014, 03:05 AM) *
Is it possible to get a full version of this wiring diagram? This is better than any of the ones I have!
jsaum   Ventilating System no blow!   Oct 2 2014, 11:26 PM
AvalonFal   I can tell you how a '74 works because I just ...   Oct 3 2014, 07:07 AM
cary   What you have in fingers is the indicator bulb hol...   Oct 3 2014, 07:18 AM
BeatNavy   I also JUST went through this on a '72. I agr...   Oct 3 2014, 07:56 AM
Philip W.   ive started the process of trying to get mine work...   Oct 3 2014, 09:37 AM
jsaum   OK thanks for all the great info it all makes sens...   Oct 3 2014, 10:35 AM
AvalonFal   OK thanks for all the great info it all makes sen...   Oct 3 2014, 10:39 AM
BeatNavy   I tore into my '72 fan housing too look at the...   Oct 3 2014, 05:25 PM
BeatNavy   I tore into my '72 fan housing too look at th...   Oct 4 2014, 09:25 AM
jsaum   Well I made some progress but no sucess in getting...   Oct 3 2014, 09:56 PM
etcmss   relay is on the main fuse panel. http://bowlsby.ne...   Oct 4 2014, 04:08 AM
jsaum   Does anyone have a picture of the wiring harness f...   Oct 4 2014, 12:08 PM
AvalonFal   Does anyone have a picture of the wiring harness ...   Oct 4 2014, 01:23 PM
jsaum   OK that explains why I can't find it! I ch...   Oct 4 2014, 01:50 PM
etcmss   attached wiring drawing for 72-73. the lights ar...   Oct 5 2014, 04:05 AM
jsaum   attached wiring drawing for 72-73. the lights a...   Oct 9 2014, 02:33 PM
clapeza   [quote name='etcmss' post='2094145' date='Oct 5 2...   Oct 9 2014, 03:27 PM
jsaum   I made some progress at the fuse box figured out w...   Oct 9 2014, 11:05 PM
Philip W.   so (jsaum) what did you find out on this? was the ...   Oct 31 2014, 09:23 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:03 PM
