| jsaum |
Oct 2 2014, 11:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm trying to get everything working on my 72 914 including the fresh air blower and defroster control on the dash. I traced down the power going to the control selector lever for the three speeds, the red & white wire which does have 12 volts but it doesn't connect to anything! Am I missing a connector or a wiring harness that gets power to the blower motor from the dash? There isn't any bulbs or holders for the red and blue bezels on the control panel it seems like there should be more there!
Thanks for the help! Jsaum Attached thumbnail(s) |
| jsaum |
Oct 9 2014, 11:05 PM
I made some progress at the fuse box figured out which relay is used for the fresh air blower and confirmed that the relay and 12 volts are working correctly. I was able to get 12 volts reading on wire #9 coming out of the fuse box on fuse #12.
Once the ignition key is turned on power is sent through the relay giving power to the blower and when the control level is actuated grounding the circuit it should come on. I used a jumper to the white and green wire to ground and got nothing. Here are pictures of the relay and wire. It looks like I'll havbe to pull the blower. Attached thumbnail(s) Attached image(s)
jsaum Ventilating System no blow! Oct 2 2014, 11:26 PM
AvalonFal I can tell you how a '74 works because I just ... Oct 3 2014, 07:07 AM
cary What you have in fingers is the indicator bulb hol... Oct 3 2014, 07:18 AM
BeatNavy I also JUST went through this on a '72. I agr... Oct 3 2014, 07:56 AM
Philip W. ive started the process of trying to get mine work... Oct 3 2014, 09:37 AM
jsaum OK thanks for all the great info it all makes sens... Oct 3 2014, 10:35 AM
AvalonFal
OK thanks for all the great info it all makes sen... Oct 3 2014, 10:39 AM
BeatNavy I tore into my '72 fan housing too look at the... Oct 3 2014, 05:25 PM
BeatNavy
I tore into my '72 fan housing too look at th... Oct 4 2014, 09:25 AM
jsaum Well I made some progress but no sucess in getting... Oct 3 2014, 09:56 PM
etcmss relay is on the main fuse panel.
http://bowlsby.ne... Oct 4 2014, 04:08 AM
jsaum Does anyone have a picture of the wiring harness f... Oct 4 2014, 12:08 PM
AvalonFal
Does anyone have a picture of the wiring harness ... Oct 4 2014, 01:23 PM
jsaum OK that explains why I can't find it! I ch... Oct 4 2014, 01:50 PM
etcmss attached wiring drawing for 72-73.
the lights ar... Oct 5 2014, 04:05 AM
jsaum
the lights a... Oct 9 2014, 02:33 PM
clapeza
[quote name='etcmss' post='2094145' date='Oct 5 2... Oct 9 2014, 03:27 PM
Philip W. so (jsaum) what did you find out on this? was the ... Oct 31 2014, 09:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:35 PM |
