| HarveyH |
Aug 23 2004, 08:48 AM
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Every now and the, someone asks about modified distributor rotors for use with high energy ignitions. The higher voltage and current produced by high-energy ignition systems has been known to burn out the internal resistor in distributor rotors. Of course, these failures always seem to occur at the most inopportune times, so it’s a good idea to be ready. You can buy modified rotors from Aircooled.net for less than $20, or make your own if you’re feeling cheap. I seem to remember that a while back Aircooled.net had this process posted on their website, but I can’t find it. I’m cheap, and I’m also ready for an arts and crafts project, so I’m going to make up a couple and document the process.
Harvey Things you’ll need: Rotor, new or used. Since the primary failure of a rotor is in the internal resistor, if the tip and contact aren’t too badly burned, they can be polished up and re-used. Soldering iron, solder, and flux. #12 wire. AWG #12 wire is rated at 20 Amps, so that should be more than enough. Epoxy. Since there is no real structural use here, choice of an epoxy is not too critical. Generally, longer cure times tend to indicate higher bond strength and higher temperature ratings. Attached image(s)
| HarveyH |
Aug 23 2004, 08:52 AM
Run the cutting burr up under the center contact to cut a passage for the new wire, but leave the contact securely bonded to the rotor.
HarveyH High Energy Distributor Rotor Aug 23 2004, 08:48 AM
HarveyH Dust Mask. I’ve never noticed it before, but on... Aug 23 2004, 08:50 AM
HarveyH Dremel tool or die grinder with a small cutting bu... Aug 23 2004, 08:51 AM
HarveyH Wear your dust mask!
Use the Dremel with a sma... Aug 23 2004, 08:52 AM
HarveyH Forgot to post the picture :confused: Aug 23 2004, 08:54 AM
HarveyH Gently run the cutting burr against the connection... Aug 23 2004, 08:55 AM
HarveyH Strip the insulation off of about 1-1/2” of #12 ... Aug 23 2004, 08:56 AM
HarveyH Put a little soldering flux on the connection tabs... Aug 23 2004, 08:56 AM
HarveyH Mix the epoxy in accordance with the manufacturers... Aug 23 2004, 08:57 AM
HarveyH When the epoxy is fully cured, use a small piece o... Aug 23 2004, 08:58 AM
McMark Great write-up. Thanks Harvey! :trophy: Aug 23 2004, 09:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th July 2026 - 12:36 AM |
