| Kraftwerk |
Aug 22 2014, 02:11 PM
Member ![]() ![]() Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
(UPDATED with nice photo's below)
Looking find or restore the electrical end of the starter cylinder, where the black disc with the six contacts meets the copper bit has become separated. There was a tiny bit of corrosion and the switch malfunctioned. The lock and Key seem to be fine. I left the roof off and rain got in there. (doh!) So I took everything apart to investigate the switch and contacts may be okay but its hard to tell a tiny spring popped out of somewhere, the other tiny spring is still in the center. The wires have been cut and soldered twice before reaching the 20 pin connector so someone has been in there before it looked kind of scrappy so I will make clean connections. The car is a 1971, later build. Secondly I want to drive my car since it is otherwise running like a top ( Thanks to Chris and Co. at Tangerine : ) Any clues on how to hot-wire it or add a temporary switch? Here is a list of wires: 1. Red (Has a tiny burn mark on contact side) 2. Red and Black 3. gray 4. Black 5.Black and Yellow Brown ( becomes Brown w/blue stripe) thanks guys! |
| Kraftwerk |
Oct 13 2014, 01:30 PM
Here is the 1st issue I have with the replacement part: It has 2 LESS wires. Old one has 6 new one has 4. |
Kraftwerk electrical end of the lock cylinder Aug 22 2014, 02:11 PM
Cap'n Krusty I would just buy a new switch. The part number is ... Aug 22 2014, 02:26 PM
Kraftwerk Exactly what I as looking for! Thank You Cap... Aug 22 2014, 02:55 PM
mikesmith ASSUMING that the wires on the switch are still th... Aug 22 2014, 11:49 PM
Harpo I ran a wire from the solenoid (yellow wire) to th... Aug 23 2014, 06:34 AM
Kraftwerk Thanks guys will try that later on.. Aug 23 2014, 08:57 AM
Kraftwerk Ok so the part arrives and it has two major
Differ... Sep 23 2014, 11:41 AM
Kraftwerk Oh yeah, and I can't hot wire the car either.
... Sep 23 2014, 11:45 AM
Harpo If the starter is running but your engine is not t... Sep 23 2014, 12:12 PM
Cap'n Krusty In order to start the car by hotwiring it, you... Sep 23 2014, 01:46 PM
Kraftwerk
2nd issue: With the new part (on right) rotatin... Oct 13 2014, 01:36 PM
Kraftwerk So that is when I got adventurous and decided just... Oct 13 2014, 01:45 PM
Kraftwerk Here is another shot of the parts inside, incase y... Oct 13 2014, 01:48 PM
Kraftwerk 'Rebuilt' switch still not working. Still ... Oct 13 2014, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2025 - 07:26 AM |
