> New guy carb question- how to select the right jets?
Chily89
post Oct 13 2014, 07:28 PM
I'm helping my friend get his car working correctly. We are having some carb issues. What is the process for getting the correct idle jets? I have read instructions on the redline website but I'm still having issues. The 914 is a 4cyl 2270 with dual weber 44 Idf's.
I read something about removing the main stacks then driving around. Can somebody please explain this method further.
McMark
post Oct 14 2014, 09:29 PM
914 Freak!
What you're describing about the AFR sounds like narrow-band activity. Something is weird with your setup. You need to get that working right as the first step. Most AFR setups can be programmed to act like a narrow band sensor. Lets work on that first. What model AEM gauge do you have?
stugray - Narrowband AFR gauges are nearly useless. Wideband are very useful.
stugray
post Oct 14 2014, 10:00 PM
QUOTE(McMark @ Oct 14 2014, 09:29 PM) *
I have an innovate LC-1 which is a wideband.
The other guys at the track that have WB AFR all say that the measurement cannot be trusted unless you are at WOT.
My datalogs back that up.
The numbers are all over the place unless you are basically in a steady pull.
It's still better than not having one, but trying to tune via AFR at idle in the garage will drive you nuts.
- Lo-Fi Version Time is now: 9th July 2025 - 03:51 PM
