| ezbngreen914 |
Oct 17 2014, 05:36 PM
Member ![]() ![]() Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States |
Pretty sure the 911 turbo has nothing to do with it, but it was a bad ass drive...
Anyway, Took the 914 out for an end of the week drive and when I shifted into 4th it went into 2nd, which sounded cool when the engine revved and the tires barked but on the second try (at a lower speed) still 2nd and not 4th. I need 4th. I turned around and headed back to the house and when I was looking for 1st I am pretty sure I found 3rd. I also need 1st. I'm thinking that something in the linkage broke and hopefully this is a problem outside of the transmission. I'm going to dig around tomorrow or maybe later tonight but I just wanted to see if anyone had any educated guess on what the problem might be. If it turns out that my 914 will not let me drive other cars with out pitching a fit, then we may have a problem... |
| Hank914 |
Oct 18 2014, 08:17 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Bushings and screws. You probably already knew this, but a good tech article with pics. From Pelican. http://www.pelicanparts.com/techarticles/9...ift_improve.htm Also for 72 and earlier folks they have tail shift info. And on this site there are good mods for non-standard bushings. If you are doing bushings check the metal bearing one somebody has done for the firewall. Tons of info on shifters on both sites. Not much on jealous 914 behavior though! (IMG:style_emoticons/default/smile.gif) |
| ezbngreen914 |
Oct 18 2014, 12:05 PM
(IMG:style_emoticons/default/agree.gif) Bushings and screws. You probably already knew this, but a good tech article with pics. From Pelican. http://www.pelicanparts.com/techarticles/9...ift_improve.htm Also for 72 and earlier folks they have tail shift info. And on this site there are good mods for non-standard bushings. If you are doing bushings check the metal bearing one somebody has done for the firewall. Tons of info on shifters on both sites. Not much on jealous 914 behavior though! (IMG:style_emoticons/default/smile.gif) I actually hadn't gotten around to that yet. Thanks for the link. Pelican tech articles have been very helpful in the past. (IMG:style_emoticons/default/beerchug.gif) |
ezbngreen914 Drove a friends 911 Turbo, now my 914 doesn't work... Oct 17 2014, 05:36 PM
Java2570 Look for loose or missing cone screws where the li... Oct 17 2014, 05:45 PM
Dave_Darling Yup, start checking the linkage. Especially every... Oct 17 2014, 09:01 PM
RobW That messy that fast you either lost your firewall... Oct 18 2014, 06:09 AM
ezbngreen914 Thanks everybody! I'm going to check it ou... Oct 18 2014, 06:42 AM
r_towle You need to talk to Naro.
He understand just how t... Oct 18 2014, 08:34 AM
ezbngreen914
I think this might be part of the problem. :bee... Oct 18 2014, 05:39 PM
ezbngreen914 Anyone got suggestions on a vendor for all the wea... Oct 18 2014, 05:49 PM
Hank914 I used Pelican since they got a bushings kit with ... Oct 18 2014, 07:07 PM
Hank914 And more on the topic on this site:
http://www.914... Oct 18 2014, 07:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:36 PM |
