| shconer |
Sep 4 2014, 03:09 PM
Newbie ![]() Group: Members Posts: 6 Joined: 4-September 14 From: Canada Member No.: 17,863 Region Association: Canada |
I have built a prototype board that adapts the factory Bosch D-Jetronic card edge connector in my 1969 Squareback to the DB-37 connector of my Megasquirt 2. Also I retrofitted the factory pressure sensor with a modern sensor inside. With some small modifications to the Megasquirt board to accommodate the external MAP sensor. I have created a plug and play system that works with the factory harness and does not require any further modifications or additions. Alternately you could instead connect the standard Megasquirt onboard MAP sensor with a hose to the manifold and lose the factory appearance. I have done some testing with the prototype board and I am in the final stages of developing the final version. I have designed it to be compatible with early and late type 3 cars as well as all fuel injected 914's. Before I ordered PCBs and components I thought I would see if there is any interest out there for something like this. The final PCB is designed to mount inside of the factory case with room for the Megasquirt. An assembled adapter would cost approximately $80 CAD. This could be a cheaper solution for someone with a malfunctioning D-Jet ECU or a dual carb conversion. The factory idle control system still controls idle. This is a fuel only set up and the factory distributor and ignition is used. Also there is no provision for EGO feedback, it is a open loop system. This adapter works with MS1 or MS2 V3.0/3.52.
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.6.jpg) |
| shconer |
Oct 22 2014, 08:22 PM
This is an intriguing project, so I did some looking at a D-Jet distributor. The Trigger points are never closed at the same time, and each side is closed for 180 degrees of the distributor rotation. So how about this: Program the megasquirt to treat the transition from closed to open as the Top Dead Center trigger. Use the ignition points as the "crank" trigger. You can use a standard pertronix or crane trigger to run them. Using the pertronix would requiring adding another 4 magnets. The crane is easier, just cut 4 more slots in the trigger disk. You would have to lock the mechanical advance in the distributor to keep the timing accurate. But that just requires taking out the breaker plate and replacing the springs with some solid link. Funny you should say that. I had a similar idea that I am also working on. Replacing the points with a cam and crank trigger wheel inside the distributor and a PCB with dual hall sensors. I have designed a PCB to replace the points and 3D printed a few trigger wheels to prove the idea. But this would be better suited to a more complex system with individual coil packs and sequential injection. An install not interested in keeping an original appearance but a clean install. (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1414030951.1.jpg) |
| mr2by4 |
Oct 22 2014, 09:53 PM
Member ![]() ![]() Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
Funny you should say that. I had a similar idea that I am also working on. Replacing the points with a cam and crank trigger wheel inside the distributor and a PCB with dual hall sensors. I have designed a PCB to replace the points and 3D printed a few trigger wheels to prove the idea. But this would be better suited to a more complex system with individual coil packs and sequential injection. An install not interested in keeping an original appearance but a clean install. (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1414030951.1.jpg) Now that is something I need! |
shconer BOSCH D-Jetronic Megasquirt Adapter Sep 4 2014, 03:09 PM
Java2570 Thanks for posting here on the World, I saw this t... Sep 4 2014, 03:27 PM
mapguy This is really interesting. I'm not in the mar... Sep 4 2014, 03:48 PM
shconer This adapter is mostly a passive device. Because t... Sep 4 2014, 04:42 PM
JamesM
This adapter is mostly a passive device. Because ... Sep 4 2014, 05:30 PM
shconer
I am not sure I understand what you mean. My des... Sep 4 2014, 10:14 PM
JamesM
On the injector circuit change, I just mean tha... Oct 21 2014, 02:57 PM
shconer Modified mounting holes.
http://www.914world.com... Sep 4 2014, 11:42 PM
Rotary'14 I like what you are doing!
but I do have a ... Sep 5 2014, 08:39 AM
monkeyboy Robert, if you are looking to do that and you don... Sep 6 2014, 07:44 AM
Rotary'14
Robert, if you are looking to do that and you don... Sep 6 2014, 08:01 AM
Bebosko
Robert, if you are looking to do that and you don... Feb 6 2015, 01:59 PM
carl07760 i am looking to convert a 2.0 EFI to webers dual c... Oct 21 2014, 11:30 AM
r_towle Can the fuel map be manipulated using this system?... Oct 21 2014, 07:38 PM
shconer I am still working on the design. I have since dis... Oct 22 2014, 12:30 AM
ClayPerrine This is an intriguing project, so I did some looki... Oct 22 2014, 06:55 AM
revhi109 I like everything I am seeing here. I really want ... Oct 28 2014, 10:00 AM
monkeyboy I have mine running already, but the adapter for t... Feb 6 2015, 02:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 03:16 AM |
