Changing empi venturis, Does it really matter? |
BK911 |
Oct 23 2014, 12:20 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
'72 1.7
Pulled the FI off several years ago and installed a set of EMPI 40s. Basically pulled them right out of the box and bolted them on. Car runs pretty well and plugs all look good. Over the weekend I was messing around and noticed the vents were 28mm. Just did the calc and it said I should have 30mm vents. So... should I? How much of a difference will it really make? With new vents goes new main and idle jets too? |
maf914 |
Oct 23 2014, 02:31 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
40mm IDF's with 28mm vents should be fine for a 1.7. I had 40mm IDF's with 28mm on my 2.0 with a mild street carb cam and it ran well and had very good gas mileage as well. Low end and mid-range were good, very drivable. Go with it.
Lo-Fi Version | Time is now: 1st June 2024 - 01:59 AM |
