Changing empi venturis, Does it really matter? |
BK911 |
Oct 23 2014, 12:20 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
'72 1.7
Pulled the FI off several years ago and installed a set of EMPI 40s. Basically pulled them right out of the box and bolted them on. Car runs pretty well and plugs all look good. Over the weekend I was messing around and noticed the vents were 28mm. Just did the calc and it said I should have 30mm vents. So... should I? How much of a difference will it really make? With new vents goes new main and idle jets too? |
BK911 |
Oct 23 2014, 04:13 PM
Thanks guys. Just making sure I wasn't leaving lots of power on the table. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis |
Oct 23 2014, 07:57 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Thanks guys. Just making sure I wasn't leaving lots of power on the table. (IMG:style_emoticons/default/biggrin.gif) You might be down 1 or 2 HP at 5500 rpm. The bigger venturis work well at high engine speed. Most of us don't stay at that rpm for long. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:20 AM |
