> rotors, how to seat them correctly
cpavlenko
post Oct 23 2014, 09:41 PM
I got some new front rotors, wheel bearings, and seals. I've seen a tread on how to do this, but can't find it. The seating of the rotor, how tight. Also went to adjust rear inner clearance on rear pads, but there where no gears in them, lol, so i called PMB, and there sending me new gears, copper seals, and the new better caps. Any suggestions. (IMG:style_emoticons/default/blink.gif) I've done rotors before, but not on the 914. Just want to make sure its done correctly, thanks.
cpavlenko
post Oct 24 2014, 08:43 AM
What type of tool needed for cv bolts and torque specs.
Cap'n Krusty
post Oct 24 2014, 10:11 AM
Cap'n Krusty
QUOTE(cpavlenko @ Oct 24 2014, 07:43 AM) *
Most 914s now have 8mm triple square fasteners. Earlier models came with 6mm Allen head fasteners. As a result, some cars have had some of the bolts changed, some not. You're gonna have to look. Clean out the internal sockets before using either tool. The torque spec I use is 35 ft/lbs.
The Cap'n
stugray
post Oct 24 2014, 04:29 PM
QUOTE(Cap'n Krusty @ Oct 24 2014, 10:11 AM) *
The Cap'n
He really means that!
#1 cause of stripping those bolts is crap down inside the bolt head.
Hit em with WD40 or engine cleaner and let em soak overnight and then hit em again and clean them out good.
- Lo-Fi Version Time is now: 2nd April 2026 - 05:09 PM
