WTB: Steel Vacuum Line Connectors, 3 needed for 2.0 FI? |
gcrotvik |
Oct 27 2014, 07:43 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I need the steel sleeve that connect the vacuum line from the air cleaner box to the Aux Air Regulator. After looking at the 2.0 FI diagram, it appears there may be 2 additional sleeves used on the 73-74 FI system?
I'm looking for sleeves that aren’t damaged on the ends from pliers, etc. See pictures below for clarification. Dimensions are: 13MM OD, 11MM ID, 40MM in length. Thanks, Greg Attached image(s) |
914Sixer |
Oct 27 2014, 02:57 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If all else fails, you might try 1/2" copper pipe. Metric tubing is available from McMaster Carr but you have to buy a long piece and it ships oversize.
gcrotvik |
Oct 27 2014, 03:17 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 06:50 PM |
