D-Jet questions, Air flow meter and head temp |
OU8AVW |
Oct 28 2014, 07:19 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I am hooking up all the D-Jet components and i have a few questions. My motor is a 2.0 out of a 1975 car built to a 2056 with a Raby FI cam. I'm using all stock FI.
I might have forgotten something. I have my head temp sender but I'm not sure how it connects. Tin is installed so I see that is goes into the hole next to the #3 intake but does it screw into the head somewhere? Do i have to pull the tin off to install it? (IMG:style_emoticons/default/dry.gif) Next: I see on my harness a plug for the air flow meter but my car came with a stupid aftermarket air cleaner. Where shiuld the AFM be? Is it attached to the stock air cleaner like my bus and 944 or is it a separate thing attached next to the battery tray? One more: My heads have two breather holes each adjacent to the intakes. I am told I should block these off. Anyone know what thread they are? When I got the car they were blocked with bronze pipe fittings. Should I make one of these a proper breather? Thanks! |
type47 |
Oct 28 2014, 07:56 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I have my head temp sender but I'm not sure how it connects. cylinder head temperature sensor is a 14mm ring that is installed under the spark plug unless you're talking about the FI sensor, my bad. Sensor for FI, not cylinder head temp gauge, is in a threaded hole on the head; somewhat awkward to get to. I see on my harness a plug for the air flow meter but my car came with a stupid aftermarket air cleaner. Where should the AFM be? Is it attached to the stock air cleaner like my bus and 944 or is it a separate thing attached next to the battery tray? hmmm, this makes me think you have L-Jet not D-Jet. L-Jet has an air flow meter, D-Jet has a Manifold Pressure Sensor. There was a L-Jet 1.8 in '75 My heads have two breather holes each adjacent to the intakes. head breather tubes are connected to an anti-flashback valve (3 way "valve") then to the air cleaner housing But on the other hand, these holes could be holes for the emission equipment. The have to be plugged if you remove the emission stuff. I've heard that you can use an old valve adjust screw to close it up. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:38 AM |
