Piston oil squirters for a /4...anyone have them? |
Mueller |
May 26 2003, 02:20 PM
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
ChrisFoley |
Oct 28 2014, 07:05 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Notching the rods is simple and effective.
aircooledtechguy |
Oct 28 2014, 10:30 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Notching the rods is simple and effective. (IMG:style_emoticons/default/agree.gif) Takes about 2 minutes per rod with a fine triangle file. Oil is lazy just like air and will take the path of least resistance. Give it a pathway and you'll have a cheap and effective stream of oil at the base of your piston. Basically you're funneling the oil that would otherwise splash off the rod from the rod bearing and directing a portion of that splash where you want it at the piston crown. |
McMark |
Oct 28 2014, 06:44 PM
directing a portion of that splash where you want it at the piston crown. But I still highly doubt this comes out as a stream. I suspect this increases the amount of oil being slung by the crank, which increases the amount of oil hitting the back of the piston. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:48 PM |
