> 914/6 oil leak, Case stud question
bcheney
post Oct 12 2014, 12:53 PM
I have an original 6 engine in my 6 conversion car. I have an oil leak at the stud circled in the pic below. I have tried to torque the nut on this stud without success. I then double nutted the stud to see if maybe the stud and become loose. I was able to turn the stud in a bit so I thought I was making progress. When I removed the double nuts and placed a washer and nut back on to torque to value it won't snug up. Instead, as I torque the nut...the stud begins to turn out. I have a bad feeling about this....Please chime in with your wisdom.
bob
post Oct 29 2014, 12:36 PM
I had the same thing. I cleaned out the stripped threads with brake clean and a wicked long Q-Tip. (not a real Q-Tip, but one of those medical ones with material that doesn't fray...)
I bought a 150mm long tap and was able to tap about 10mm further with more threads. I found a longer stud, reinstalled it with locktite and it hasn't leaked a drop.
-bob
bcheney   914/6 oil leak   Oct 12 2014, 12:53 PM
Luke M   By the sounds of things the stud is pulling from t...   Oct 12 2014, 12:59 PM
bcheney   By the sounds of things the stud is pulling from ...   Oct 12 2014, 01:25 PM
Luke M   By the sounds of things the stud is pulling from...   Oct 12 2014, 02:28 PM
Mark Henry   . You may try the epoxy route but I don't thi...   Oct 12 2014, 02:43 PM
Mark Henry   Clean it up real good to bare metal, degrease it a...   Oct 12 2014, 02:08 PM
GeorgeRud   I had the same thing happen to me many years ago. ...   Oct 12 2014, 02:13 PM
bcheney   I had the same thing happen to me many years ago....   Oct 12 2014, 02:37 PM
rfuerst911sc   Brian sorry to hear I don't visit here often s...   Oct 12 2014, 02:46 PM
johnhora   Sorry to say I have had that same problem and noth...   Oct 12 2014, 05:45 PM
Cap'n Krusty   I fixed one without taking the engine apart. Bore...   Oct 12 2014, 06:24 PM
bcheney   I fixed one without taking the engine apart. Bor...   Oct 12 2014, 06:49 PM
sixnotfour   brake clean the hole see if you can grab a few thr...   Oct 12 2014, 06:51 PM
bcheney   brake clean the hole see if you can grab a few th...   Oct 29 2014, 05:22 AM
Luke M   It depends if you are taking the engine apart a...   Oct 29 2014, 07:59 AM
bcheney   Ok I removed the stud just a little while ago and ...   Oct 29 2014, 09:40 AM
carr914   Did you send the picture to Mike? Tell Leslie she...   Oct 29 2014, 06:27 AM
Luke M   That doesn't look good.. It's time to spli...   Oct 29 2014, 12:00 PM
bob   I had the same thing. I cleaned out the stripped t...   Oct 29 2014, 12:36 PM
bcheney   I had the same thing. I cleaned out the stripped ...   Oct 29 2014, 01:10 PM
gereed75   I had the same thing. I cleaned out the stripped...   Oct 29 2014, 01:22 PM
bcheney   [quote name='bcheney' post='2104066' date='Oct 29...   Oct 29 2014, 04:04 PM
bob   I forget where I found the tap. (maybe McMasterCar...   Oct 29 2014, 01:40 PM
bcheney   I forget where I found the tap. (maybe McMasterCa...   Oct 29 2014, 04:05 PM
bob   yeah. I measured the original stud and the hole. t...   Oct 29 2014, 05:42 PM
gereed75   sorry I did not post sooner. Just got to the shop...   Nov 1 2014, 08:53 AM
bcheney   sorry I did not post sooner. Just got to the sho...   Nov 1 2014, 03:16 PM
bcheney   yeah. I measured the original stud and the hole. ...   Nov 2 2014, 10:04 PM
bcheney   yeah. I measured the original stud and the hole. ...   Nov 6 2014, 06:17 AM
gereed75   Never thought that the threads might go deeper. It...   Nov 1 2014, 05:07 PM
wndsnd   Not sure the threads are deeper but I do think the...   Nov 1 2014, 05:19 PM
sixnotfour   http://www.mcmaster.com/#99067A248 you cut to cut...   Nov 2 2014, 10:20 PM
sixnotfour   darn double post :beer2:   Nov 2 2014, 10:23 PM
bob   that sux... sorry to hear that the depth is differ...   Nov 6 2014, 06:55 AM
bcheney   that sux... sorry to hear that the depth is diffe...   Nov 6 2014, 09:15 AM
gereed75   I had a chance to pull this stud yesterday. The de...   Nov 9 2014, 09:32 AM
bcheney   I had a chance to pull this stud yesterday. The d...   Nov 9 2014, 05:26 PM
Luke M   [quote name='gereed75' post='2108416' date='Nov 9...   Nov 9 2014, 06:10 PM
gereed75   I have a couple of Ideas depending on what all I d...   Nov 9 2014, 06:15 PM
gereed75   Bcheney, check your PM's. And I see from pre...   Nov 14 2014, 11:07 AM
mepstein   Get a pro to time sert. See what Joe O'brien c...   Nov 6 2014, 07:23 AM
- Lo-Fi Version Time is now: 1st August 2025 - 07:12 AM
