bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
I have an original 6 engine in my 6 conversion car. I have an oil leak at the stud circled in the pic below. I have tried to torque the nut on this stud without success. I then double nutted the stud to see if maybe the stud and become loose. I was able to turn the stud in a bit so I thought I was making progress. When I removed the double nuts and placed a washer and nut back on to torque to value it won't snug up. Instead, as I torque the nut...the stud begins to turn out. I have a bad feeling about this....Please chime in with your wisdom.
Attached image(s) ![]() |
bob |
Member ![]() ![]() Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None ![]() ![]() |
I had the same thing. I cleaned out the stripped threads with brake clean and a wicked long Q-Tip. (not a real Q-Tip, but one of those medical ones with material that doesn't fray...)
I bought a 150mm long tap and was able to tap about 10mm further with more threads. I found a longer stud, reinstalled it with locktite and it hasn't leaked a drop. -bob |
bcheney |
I had the same thing. I cleaned out the stripped threads with brake clean and a wicked long Q-Tip. (not a real Q-Tip, but one of those medical ones with material that doesn't fray...) I bought a 150mm long tap and was able to tap about 10mm further with more threads. I found a longer stud, reinstalled it with locktite and it hasn't leaked a drop. -bob This is encouraging! Where did you find the 150mm long tap and longer stud? How long has it been since the repair or how many miles? |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,373 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
I had the same thing. I cleaned out the stripped threads with brake clean and a wicked long Q-Tip. (not a real Q-Tip, but one of those medical ones with material that doesn't fray...) I bought a 150mm long tap and was able to tap about 10mm further with more threads. I found a longer stud, reinstalled it with locktite and it hasn't leaked a drop. -bob This is encouraging! Where did you find the 150mm long tap and longer stud? How long has it been since the repair or how many miles? That stud was also leaking on the T motor that is in my car. I currently have the motor out and the cases are split. I will look at what is "behind" that stud. It might give you a better idea of what you can get away with as far as "in the car" repairs. I will try to check tonight. Also please check your PM's. |
Lo-Fi Version | Time is now: 1st August 2025 - 07:08 AM |
