| malcolm2 |
Oct 30 2014, 09:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
'75 1911 L-Jet with about 7000 miles on it, and a fresh oil change this week. Fresh injectors before the first test. Probably running 87 oct E10 gas today. Might have been 93 100% last year.
12 months ago I passed the HC 399 limit 500 CO 0.65 limit 5.0 CO2 11 no limit listed and from just moments ago 10/2014: HC 428 limit 500 CO 3.83 limit 5.0 CO2 11.53 no limit listed 2 different inspection stations, not sure if that matters. The CO seems to have jumped. I did tweek a few teeth on the AFM between the tests. IIRC I have moved it 9 teeth. Plus the HC is getting close to the limit. I can't remember the RPMs during either test, but they tend to be about 1000, a bit high. It passed but I want to be pro-active, any thoughts about the CO jump and pulling the HC down for next year? Clark |
| Cap'n Krusty |
Oct 30 2014, 12:29 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I would think that adding some clearance on an engine normally running zero clearance would work just fine. IME, the .006" clearance remains pretty much the same as the engine comes to operating temps, so adding .010-.012" should make a similar change in HC emissions. Not gonna hurt anything for the short time you're running it that way. I usually run the tank low and add only 4-5 gallons of regular, not a full tank. You really need to set the AFM with a CO machine ...
The Cap'n |
malcolm2 HC levels on emissions test.... PASSED Oct 30 2014, 09:52 AM
era vulgaris That's a bummer you have to get your car inspe... Oct 30 2014, 10:38 AM
malcolm2
That's a bummer you have to get your car insp... Oct 30 2014, 11:07 AM
GregAmy Interesting you have to go through emissions...eve... Oct 30 2014, 10:49 AM
Cap'n Krusty
'75 1911 L-Jet with about 7000 miles on it, a... Oct 30 2014, 10:52 AM
malcolm2
I've been preparing cars for smog checks he... Oct 30 2014, 11:24 AM
mepstein Move to PA. One time fee of $75 for life anti... Oct 30 2014, 12:43 PM
malcolm2
Move to PA. One time fee of $75 for life ant... Oct 30 2014, 02:02 PM
Move to PA. One time fee of $75 for life an... Oct 30 2014, 03:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 11:46 AM |
