| got914? |
Oct 30 2014, 05:36 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
It started the day I got it home but ran outa gas. I put gas in it and now all it does is turn and turn. Ive never had a carbd car without a choke and this dint have one I dont think. Is there a trick to starting them ?
| r_towle |
Oct 30 2014, 08:28 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Replace the fuel filter,
| Root_Werks |
Oct 31 2014, 07:33 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,066 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Replace the fuel filter, (IMG:style_emoticons/default/agree.gif) Could be since you ran it out of gas you've tossed up some 'gunk' in the base of the tank. Could also have clogged up the fuel strainer? Could also have burned up the fuel pump running it dry? Could also be poor fuel line routing not allowing the pump to prime could also be..... (IMG:style_emoticons/default/confused24.gif) |
got914? trick to starting a 1.7 ? Oct 30 2014, 05:36 PM
michael7810 Can you hear the fuel pump running? If so pull th... Oct 30 2014, 06:21 PM
wndsnd I agree, turn the key and listen for fuel pump, wa... Oct 30 2014, 07:44 PM
dw914six
:agree: running out of... Oct 31 2014, 08:43 PM
Vacca Rabite Cold starting a carbed 914 can be a little tricky.... Oct 31 2014, 07:57 AM
Racer Chris
You need to keep the peddle down a bit until the ... Oct 31 2014, 08:30 AM
wndsnd
You need to keep the peddle down a bit until the... Oct 31 2014, 02:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st October 2026 - 05:01 PM |
