> How to check for vacuum leaks, What are the tips and tricks ?
913B
post Oct 31 2014, 06:15 PM
From the last time I tried with the engine running and spraying carb cleaner everywhere and causing a big mess. I did not really see a big RPM difference, maybe I was doing it wrong, maybe I was expecting too big a change and moved on too quickly, but nothing really came from it. I still suffer from a periodic hi idle (1500 rpm), sometimes it idles fine at 800. If it was a vacuum leak why did it correct itself and sometimes idle at 800 ? I have since removed the AAR and even swapped out the MPS with another one, no difference. Stock 1.7 FI
So the discussion for today is what is the proper method, tips and tricks to perform a good vacuum leak check.
I am tempted to make a DIY homemade smoke machine from watching youtube to blow smoke in my FI system and check it that way ??
Thoughts (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
r_towle
post Nov 1 2014, 08:54 AM
Custom Member
Go back to the issue.
A periodic high idle , in my opinion, is not a vacuum leak.
I would look at cleaning your distributor advance plates and regreasing them.
- Lo-Fi Version Time is now: 2nd May 2026 - 06:39 AM
