D-Jet questions, Air flow meter and head temp |
OU8AVW |
Oct 28 2014, 07:19 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I am hooking up all the D-Jet components and i have a few questions. My motor is a 2.0 out of a 1975 car built to a 2056 with a Raby FI cam. I'm using all stock FI.
I might have forgotten something. I have my head temp sender but I'm not sure how it connects. Tin is installed so I see that is goes into the hole next to the #3 intake but does it screw into the head somewhere? Do i have to pull the tin off to install it? (IMG:style_emoticons/default/dry.gif) Next: I see on my harness a plug for the air flow meter but my car came with a stupid aftermarket air cleaner. Where shiuld the AFM be? Is it attached to the stock air cleaner like my bus and 944 or is it a separate thing attached next to the battery tray? One more: My heads have two breather holes each adjacent to the intakes. I am told I should block these off. Anyone know what thread they are? When I got the car they were blocked with bronze pipe fittings. Should I make one of these a proper breather? Thanks! |
OU8AVW |
Nov 1 2014, 10:43 AM
So, heads are bass akwards. What's the penalty for leaving them and pulling head temp off of #1? Any other issues?
ClayPerrine |
Nov 1 2014, 10:55 AM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
So, heads are bass akwards. What's the penalty for leaving them and pulling head temp off of #1? Any other issues? The #3 cylinder is farthest from the cooling fan, so it runs hotter than all the others. You need to put the sensor in the correct location so it receives the correct temp. Otherwise it will run too rich. IIRC, the sensor is a 10 x 1.0 thread, so just pull the right hand tin to drill and tap the head. The boss is cast in the head, and you don't have to drill it deep. |
OU8AVW |
Nov 1 2014, 01:36 PM
So, heads are bass akwards. What's the penalty for leaving them and pulling head temp off of #1? Any other issues? The #3 cylinder is farthest from the cooling fan, so it runs hotter than all the others. You need to put the sensor in the correct location so it receives the correct temp. Otherwise it will run too rich. IIRC, the sensor is a 10 x 1.0 thread, so just pull the right hand tin to drill and tap the head. The boss is cast in the head, and you don't have to drill it deep. Cool.... |
Lo-Fi Version | Time is now: 6th June 2024 - 04:27 AM |
