> Window delrin rollers, On a late car...
jim_hoyland
post Nov 1 2014, 09:16 AM
Get that VIN ?
(IMG:http://www.914world.com/bbs2/uploads/post-3348-1272991814_thumb.jpg)
I have the delrin rollers; is their a trick to getting access to replace them ? Looks very tight.
bdstone914
post Nov 1 2014, 02:34 PM
bdstone914
When you remove the regulator spray some lube in the gears. The grease may be old and hard. Test it with no load to see if that is the problem.
jim_hoyland
post Nov 1 2014, 03:02 PM
Get that VIN ?
QUOTE(bdstone914 @ Nov 1 2014, 01:34 PM) *
Does the glass have to be removed first ?
bdstone914
post Nov 1 2014, 04:59 PM
bdstone914
QUOTE(jim_hoyland @ Nov 1 2014, 02:02 PM) *
You can leave the glass in the door but have to disconnect it from the regulator.
One 13mm head bolt on the long white plastic part hold it on.
You will need a stick or some other way of holding the glass up to remove the regulator.
jim_hoyland   Window delrin rollers   Nov 1 2014, 09:16 AM
Cap'n Krusty   There are no rollers in the window channels of a l...   Nov 1 2014, 10:34 AM
jim_hoyland   See: http://shop.914rubber.com/914-Late-window-......   Nov 1 2014, 11:15 AM
Cap'n Krusty   Ahhh. As I've never had to replace those (I h...   Nov 1 2014, 11:31 AM
jim_hoyland   Is the regulator all of #2 ?   Nov 1 2014, 11:36 AM
bdstone914   Yes the regulator is all of #2. The rollers are on...   Nov 1 2014, 11:52 AM
jim_hoyland   I'm replacing them 'cause it's getting...   Nov 1 2014, 11:59 AM
bdstone914   When you remove the regulator spray some lube in t...   Nov 1 2014, 02:34 PM
jim_hoyland   When you remove the regulator spray some lube in ...   Nov 1 2014, 03:02 PM
bdstone914   When you remove the regulator spray some lube in...   Nov 1 2014, 04:59 PM
Mikey914   The easiest way to replace these (in my opinion) i...   Nov 1 2014, 10:39 PM
rgalla9146   The easiest way to replace these (in my opinion) ...   Nov 2 2014, 07:16 AM
r_towle   Do you have power windows? Could just be out of al...   Nov 2 2014, 04:53 PM
jim_hoyland   Do you have power windows? Could just be out of a...   Nov 2 2014, 05:13 PM
r_towle   I can't remember but it's either when it...   Nov 2 2014, 05:17 PM
jim_hoyland   I can't remember but it's either when it...   Nov 2 2014, 05:25 PM
r_towle   Sounds like it's crooked. Rear touches nothing...   Nov 2 2014, 06:19 PM
r_towle   Jim, look at the pics in the power window thread.....   Nov 2 2014, 07:52 PM
- Lo-Fi Version Time is now: 4th March 2026 - 03:45 AM
