| jim_hoyland |
Nov 1 2014, 09:16 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,028 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
(IMG:http://www.914world.com/bbs2/uploads/post-3348-1272991814_thumb.jpg)
I have the delrin rollers; is their a trick to getting access to replace them ? Looks very tight. |
| r_towle |
Nov 2 2014, 05:17 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I can't remember but it's either when it's up or down you can loosen the bolts and feel the tension release if it's wrong....
| jim_hoyland |
Nov 2 2014, 05:25 PM
I can't remember but it's either when it's up or down you can loosen the bolts and feel the tension release if it's wrong.... The passenger side is much slower than the driver side; I have noticed the upper RH corner of the glass has some movement fore /aft. Not a lot, but like it's wiggling to finish closing the window. |
jim_hoyland Window delrin rollers Nov 1 2014, 09:16 AM
Cap'n Krusty There are no rollers in the window channels of a l... Nov 1 2014, 10:34 AM
jim_hoyland See: http://shop.914rubber.com/914-Late-window-...... Nov 1 2014, 11:15 AM
Cap'n Krusty Ahhh. As I've never had to replace those (I h... Nov 1 2014, 11:31 AM
jim_hoyland Is the regulator all of #2 ? Nov 1 2014, 11:36 AM
bdstone914 Yes the regulator is all of #2.
The rollers are on... Nov 1 2014, 11:52 AM
jim_hoyland I'm replacing them 'cause it's getting... Nov 1 2014, 11:59 AM
bdstone914 When you remove the regulator spray some lube in t... Nov 1 2014, 02:34 PM
jim_hoyland
When you remove the regulator spray some lube in ... Nov 1 2014, 03:02 PM
bdstone914
When you remove the regulator spray some lube in... Nov 1 2014, 04:59 PM
Mikey914 The easiest way to replace these (in my opinion) i... Nov 1 2014, 10:39 PM
rgalla9146
The easiest way to replace these (in my opinion) ... Nov 2 2014, 07:16 AM
r_towle Do you have power windows?
Could just be out of al... Nov 2 2014, 04:53 PM
jim_hoyland
Could just be out of a... Nov 2 2014, 05:13 PM
r_towle Sounds like it's crooked.
Rear touches nothing... Nov 2 2014, 06:19 PM
r_towle Jim, look at the pics in the power window thread..... Nov 2 2014, 07:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 02:24 AM |
