> 2270 Build, Need advise
pilothyer
post Nov 2 2014, 08:40 PM
I am interested in building a 2270 engine. From what I can see I will need a stroker crank with a 78 mm throw. I am concerned about which rod to choose. I have seen stroker cranks with VW type 1 journals as well as 2.0 liter and chevy. I have noticed variations in rod lengths as well. I am in need of some advise on a good, proven combination. I know there are many good engine builders on his forum that could share their knowledge on this subject so please do...............Thanks
Mark Henry
post Nov 3 2014, 08:48 AM
that's what I do!
Use the type 1 rod journal, stock type 1 length CB rod. They have to be clearanced or it will hit a cam lobe. Cam also has to be a reduced base circle cam.
I'd only use the Buick (Chevy) journal on a 80+mm and I'd never use a stock rod on a stroker.
pilothyer   2270 Build   Nov 2 2014, 08:40 PM
Hine62   Check out: Your Current Type IV Build Engine Build...   Nov 3 2014, 05:39 AM
Mark Henry   Use the type 1 rod journal, stock type 1 length CB...   Nov 3 2014, 08:48 AM
pilothyer   Use the type 1 rod journal, stock type 1 length C...   Nov 3 2014, 04:26 PM
grimmel   OR....insert a used non-turbo Subie 2.5....and nev...   Nov 3 2014, 11:59 AM
Jetsetsurfshop   I did a 78mm crank and had to clearance the case. ...   Nov 3 2014, 06:19 PM
Hine62   I did a 78mm crank and had to clearance the case....   Nov 3 2014, 09:00 PM
Jetsetsurfshop   I did a 78mm crank and had to clearance the case...   Nov 3 2014, 09:27 PM
Jake Raby   Not if it adds efficiency. Its all in the combo.   Nov 3 2014, 07:41 PM
DBCooper   Not if it adds efficiency. Its all in the combo...   Nov 5 2014, 06:18 AM
Jake Raby   Not if it adds efficiency. Its all in the comb...   Nov 5 2014, 07:32 AM
craig downs   That's true, my head temp always run at 275 - ...   Nov 3 2014, 07:52 PM
Jetsetsurfshop   That's true, my head temp always run at 275 -...   Nov 3 2014, 07:57 PM
Jake Raby   That's true, my head temp always run at 275 -...   Nov 3 2014, 08:28 PM
Jetsetsurfshop   That's true, my head temp always run at 275 ...   Nov 3 2014, 08:55 PM
DBCooper   Sure, if you never use WOT you won't produce m...   Nov 5 2014, 07:47 AM
davep   It really comes down to fuel consumption; fuel = h...   Nov 5 2014, 07:57 AM
Jake Raby   He's talking about a street car here. Sure he...   Nov 5 2014, 08:28 AM
DBCooper   Odd, I never knew that you were a Physicist. No ...   Nov 5 2014, 10:12 AM
Jake Raby   My advice is to make so much power that all of i...   Nov 5 2014, 10:35 AM
r_towle   My advice is to make so much power that all of ...   Nov 5 2014, 02:58 PM
Jake Raby   My advice is to make so much power that all of...   Nov 5 2014, 05:15 PM
r_towle   [quote name='r_towle' post='2106728' date='Nov 5 ...   Nov 5 2014, 05:32 PM
Dave_Darling   Part of the disagreement would appear to be that y...   Nov 5 2014, 10:40 AM
Jake Raby   Part of the disagreement would appear to be that ...   Nov 5 2014, 11:17 AM
DBCooper   I never said that more power does not increase mo...   Nov 5 2014, 12:27 PM
gereed75   not to jump in (there are plenty of people already...   Nov 5 2014, 01:01 PM
Jake Raby   And some never do. I have guys that have been ...   Nov 5 2014, 02:23 PM
Jake Raby   I knew what you were doing.. No biggie. I bet tha...   Nov 5 2014, 05:37 PM
r_towle   This is your business, everyone knows that. For ma...   Nov 5 2014, 05:39 PM
Jake Raby   This is your business, everyone knows that. For m...   Nov 5 2014, 07:40 PM
r_towle   This is your business, everyone knows that. For ...   Nov 10 2014, 06:08 PM
Jake Raby   [quote name='Jake Raby' post='2106830' date='Nov ...   Nov 10 2014, 06:58 PM
r_towle   [quote name='Jake Raby' post='2106830' date='Nov...   Nov 11 2014, 07:04 AM
JimN73   This thread brings up a couple of things that I ha...   Nov 10 2014, 10:45 AM
Woody   If you built a 2.4 with huge bore and a small stro...   Nov 11 2014, 07:26 AM
Jake Raby   Here's the 2.6L MassIVe engine thats in my 356...   Nov 11 2014, 08:58 AM
Jake Raby   Here's a pic of the engine just after being bo...   Nov 11 2014, 08:59 AM
McMark   I knew there was a reason I didn't open this t...   Nov 11 2014, 01:36 PM
Woody   I knew there was a reason I didn't open this ...   Nov 11 2014, 01:39 PM
r_towle   Have you tried Solex carbs?   Nov 11 2014, 02:54 PM
Jake Raby   Have you tried Solex carbs? Absolutely.. Solid ...   Nov 11 2014, 09:08 PM
r_towle   Agreed on dells but I really became fond of the So...   Nov 11 2014, 09:10 PM
Jake Raby   Agreed on dells but I really became fond of the S...   Nov 11 2014, 09:24 PM
- Lo-Fi Version Time is now: 2nd November 2026 - 08:23 PM
