Help! just lost my tach, wipers, voltmeter, fuel gauge, 11-03-new question: how to id. the fresh air fan wire ----- (solution: always check and recheck fuses- #9 (4th from right) was off center not in tight |
DRPHIL914 |
Oct 31 2014, 04:19 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Don't know what happened- I also had lost my dash lights earlier, put in a new #7 fuse then o.k. then about 30 minutes later I ooze all that stuff and the center console everything - volt meter oil temp gauge and a/f meter all out- what to check first!
bdstone914 |
Nov 3 2014, 11:06 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Unbolt the control and pull it out far enough to inspect the contacts. If they look like this one it could be your problem. Also not the raised plastic between the second and third contact. I have seen this happen and raise the sliding contact and making high speed inoperative. Also check the ground wire from the control to the body under the dash.
DRPHIL914 |
Nov 3 2014, 11:59 AM
Unbolt the control and pull it out far enough to inspect the contacts. If they look like this one it could be your problem. Also not the raised plastic between the second and third contact. I have seen this happen and raise the sliding contact and making high speed inoperative. Also check the ground wire from the control to the body under the dash. The contacts look fine, clean no warping of plastic like that. I also switched the wires around and still only the wire connected in center will work so it must be the controller. I need to get a different controller that is known to work in all 3 positions to try and that would help with my trouble shooting. I have a second fresh air box I am going to bench test As well |
Lo-Fi Version | Time is now: 1st June 2024 - 01:01 PM |
