| pilothyer |
Nov 2 2014, 08:40 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I am interested in building a 2270 engine. From what I can see I will need a stroker crank with a 78 mm throw. I am concerned about which rod to choose. I have seen stroker cranks with VW type 1 journals as well as 2.0 liter and chevy. I have noticed variations in rod lengths as well. I am in need of some advise on a good, proven combination. I know there are many good engine builders on his forum that could share their knowledge on this subject so please do...............Thanks
| craig downs |
Nov 3 2014, 07:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 770 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
That's true, my head temp always run at 275 - 300 most of the time and only gets up to 325 on a climb.
pilothyer 2270 Build Nov 2 2014, 08:40 PM
Hine62 Check out:
Your Current Type IV Build
Engine Build... Nov 3 2014, 05:39 AM
Mark Henry Use the type 1 rod journal, stock type 1 length CB... Nov 3 2014, 08:48 AM
pilothyer
Use the type 1 rod journal, stock type 1 length C... Nov 3 2014, 04:26 PM
grimmel OR....insert a used non-turbo Subie 2.5....and nev... Nov 3 2014, 11:59 AM
Jetsetsurfshop I did a 78mm crank and had to clearance the case. ... Nov 3 2014, 06:19 PM
Hine62
I did a 78mm crank and had to clearance the case.... Nov 3 2014, 09:00 PM
Jetsetsurfshop
I did a 78mm crank and had to clearance the case... Nov 3 2014, 09:27 PM
Jake Raby
Not if it adds efficiency.
Its all in the combo. Nov 3 2014, 07:41 PM
DBCooper
Its all in the combo... Nov 5 2014, 06:18 AM
Jake Raby
Its all in the comb... Nov 5 2014, 07:32 AM
Jetsetsurfshop
That's true, my head temp always run at 275 -... Nov 3 2014, 07:57 PM
Jake Raby
That's true, my head temp always run at 275 -... Nov 3 2014, 08:28 PM
Jetsetsurfshop
That's true, my head temp always run at 275 ... Nov 3 2014, 08:55 PM
DBCooper Sure, if you never use WOT you won't produce m... Nov 5 2014, 07:47 AM
davep It really comes down to fuel consumption; fuel = h... Nov 5 2014, 07:57 AM
Jake Raby
He's talking about a street car here. Sure he... Nov 5 2014, 08:28 AM
DBCooper
Odd, I never knew that you were a Physicist.
No ... Nov 5 2014, 10:12 AM
Jake Raby
My advice is to make so much power that all of i... Nov 5 2014, 10:35 AM
r_towle
My advice is to make so much power that all of ... Nov 5 2014, 02:58 PM
Jake Raby
My advice is to make so much power that all of... Nov 5 2014, 05:15 PM
r_towle
[quote name='r_towle' post='2106728' date='Nov 5 ... Nov 5 2014, 05:32 PM
Dave_Darling Part of the disagreement would appear to be that y... Nov 5 2014, 10:40 AM
Jake Raby
Part of the disagreement would appear to be that ... Nov 5 2014, 11:17 AM
DBCooper
I never said that more power does not increase mo... Nov 5 2014, 12:27 PM
gereed75 not to jump in (there are plenty of people already... Nov 5 2014, 01:01 PM
Jake Raby
And some never do.
I have guys that have been ... Nov 5 2014, 02:23 PM
Jake Raby I knew what you were doing.. No biggie.
I bet tha... Nov 5 2014, 05:37 PM
r_towle This is your business, everyone knows that.
For ma... Nov 5 2014, 05:39 PM
Jake Raby
For m... Nov 5 2014, 07:40 PM
r_towle
For ... Nov 10 2014, 06:08 PM
Jake Raby
[quote name='Jake Raby' post='2106830' date='Nov ... Nov 10 2014, 06:58 PM
r_towle
[quote name='Jake Raby' post='2106830' date='Nov... Nov 11 2014, 07:04 AM
JimN73 This thread brings up a couple of things that I ha... Nov 10 2014, 10:45 AM
Woody If you built a 2.4 with huge bore and a small stro... Nov 11 2014, 07:26 AM
Jake Raby Here's the 2.6L MassIVe engine thats in my 356... Nov 11 2014, 08:58 AM
Jake Raby Here's a pic of the engine just after being bo... Nov 11 2014, 08:59 AM
McMark I knew there was a reason I didn't open this t... Nov 11 2014, 01:36 PM
Woody
I knew there was a reason I didn't open this ... Nov 11 2014, 01:39 PM
r_towle Have you tried Solex carbs? Nov 11 2014, 02:54 PM
Jake Raby
Absolutely.. Solid ... Nov 11 2014, 09:08 PM
r_towle Agreed on dells but I really became fond of the So... Nov 11 2014, 09:10 PM
Jake Raby
Agreed on dells but I really became fond of the S... Nov 11 2014, 09:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 09:26 PM |
