tach |
Member ![]() ![]() Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest ![]() |
Does anybody know what the groove dimensions are on a Shadek oil pump grooved for a O-ring. Groove width and groove depth.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I do it on all my T1 Full Flow performance pumps.
I can't/won't give you a groove dimension as you have to measure your O'ring, but I will give you these pointers. The big one is you only want about .010-.015 sticking up or the O-ring will tear on install. You also have to deburr the case inlet and outlet holes or that will tear it as well. You want a thin O-ring that is a hair small so it sits real tight in the groove. I use DOW55 O-ring lube (ebay $30 tube or you might try a scuba shop for a dab) when installing the pump, it prevents tearing and swells the O-ring after install. The T4 is harder to do, you have to check all the dimensions and be sure where the O-ring will sit when finished, I usually only do this with the engine apart. I got a bunch of O-rings from Berg years ago, I only have a couple left. I thought I once posted this mod but I can't find it. Note you can not do this to a T4 pump. |
Lo-Fi Version | Time is now: 9th July 2025 - 11:57 AM |
