| rjames |
Nov 4 2014, 04:13 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I copped to this in another post, but didn't mention the extent of the 'misadjusting' that I did. In short, *I think* I adjusted some or all of the valves when open. That is to say, when a valve was fully closed, I adjusted the opposite valve ala Krusty's method. No need to comment on how stupid this was, I get it and know how to tell when a valve is open vs closed now.
After the error was made, the engine was ran for ~5 minutes, at low RPMs. It has hydro lifters. Not surprising, it was noisy and had low power. Since then I've done a proper valvue adjustment and ran it for another ~5 minutes, and it's still noisy. Not as noisy, but noisy. But with hydro lifters I'm used to noise when the car isn't driven for awhile and then it quiets down but I was afraid to run it any longer. I plan on rechecking the valve clearance one more time before starting it up again, which I will do only because I'm at the point where I'm accepting that a rebuild is likely in my future sooner than planned. So: What is the likelihood I did permenant damage to something by setting valve clearance with the valves open? My mistake resulted in a way too loose setting for some/all of the valves, so much so that the vavles may have not opened at all or opened very little when I ran it. Given the short time I ran the engine, isn't the extent of the damage likely just to be potentially prematurely worn pushrood and lifter surfaces? And maybe there's a chance that it's noisy only because the lifters still need to do a lot of pumping up? All of the rockers are intact (save for any cracks I can't see). All of the lifters seem to have a bit of air in them as I can compress them with the pusrhod via the rockers a bit. |
| Bob L. |
Nov 4 2014, 05:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I would think there would be a chance of damage if they were too tight (valve/piston contact), not too loose.
rjames Made a big mistake when adjusting valves Nov 4 2014, 04:13 PM
76-914 I doubt there is any damage with no load, low RPM.... Nov 4 2014, 05:41 PM
rjames
I doubt there is any damage with no load, low RPM... Nov 4 2014, 05:47 PM
76-914
I doubt there is any damage with no load, low RP... Nov 4 2014, 05:57 PM
ThePaintedMan Well there's your problem. You're trying t... Nov 4 2014, 05:59 PM
a few loose screws
Well there's your problem. You're trying ... Nov 4 2014, 07:14 PM
rjames
Well there's your problem. You're trying... Nov 4 2014, 11:14 PM
ThePaintedMan I understand what you're saying, but the origi... Nov 4 2014, 07:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 07:35 PM |
