| roblav1 |
Nov 7 2014, 12:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
First, I want to positively verify that a particular 915 type Sporto coarse flange will work in the 914 box. I have two 108mm transaxle output flanges with a 925XXXXX part number indicating from a 915 Sporto (not a 901 Sporto). I carefully measured them and they are precisely the same as the 914 type (except the size of the flange!). If anyone wants it, I can get the part number off mine (they are in the shop)... I happened to see a couple of these on EBay for what I think is cheap money.
On the other side, in the trailing arm, the 108mm flange is quite the tight fit! So that and the 5 lug 911 hubs are all installed with new bearings in the trailing arms. Soooo... I intend to use new 930 type CV's and SwayAway axles. Does anyone know offhand the required axle length? I don't have the 993 engine in the car yet but want to get these things ordered. Seems to me the axles should be slightly shorter than standard 914 since the 930 CV's are a bit thicker. Yes, I have checked for this info here... if the info is here, sorry I missed it in my search! Thanks, R |
| Mark Henry |
Nov 7 2014, 06:37 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
This thread tells you all you need to know. First page gives you the axle lenghth and post #56-on shows how I did it and some of the pitfalls.
Also 108mm early tranny input shafts do not work and in this thread I show why and what to look for. http://www.914world.com/bbs2/index.php?showtopic=91963 |
roblav1 930 CV's and SwayAway Axle Length / 993 Conversion Nov 7 2014, 12:36 AM
Krieger I think the stock axle length is 20.25". The... Nov 7 2014, 01:15 AM
Krieger 944 cvs
This link may work. Some info in this th... Nov 7 2014, 01:20 AM
era vulgaris I used these chromoly axles on my car:
http://www.... Nov 7 2014, 07:36 AM
Mike Bellis I use Pacific Custom's axles with my Boxster 6... Nov 7 2014, 08:45 AM
roblav1 Thanks for all the replies and recommendations.
... Nov 7 2014, 10:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 09:13 PM |
