> I need to fix and replace some bad wiring(melted) near the fuse box, **Update 11/6 - installed j-west fuse box * started! woo hoo!
DRPHIL914
post Nov 5 2014, 07:37 AM
Dr. Phil
I am installing the new Jwwest fuse box and
I have a 3" section of wire off the #5 back row fuse that has melted insulation(grey with black stripe)
what is the best way to replace and splice in the new piece and what gauge wire is correct?
Dave_Darling
post Nov 7 2014, 10:58 AM
914 Idiot
Tape an extra spark plug to a ground, and plug in one of your plug wires. Look at the plug while someone cranks the starter; you should be able to see sparks if the ignition is working.
Your comment about the pump priming makes me think you have D-jet. Is that correct? In that case, the pump priming means that the FI ECU and pump are both getting power, which pretty much eliminates them from consideration.
Do you know you're getting fuel? Can you smell it at the tailpipe after cranking for a while? Have you tried putting the injectors in jars and looking for fuel to come out? Do you know you're getting spark? How about compression?
--DD
DRPHIL914
post Nov 7 2014, 12:49 PM
Dr. Phil
QUOTE(Dave_Darling @ Nov 7 2014, 11:58 AM) *
--DD
Dave
- yes its d-jet. and yes after cranking a bit you do smell the gas. - but after i check the electrical side if it all checks out i will pull and test each injector- they were brand new NOS stock i got from Otto's Venice last year. only have aboiut 2k miles on it since installing it. - i dont use ethanol gas hardly ever and always put stabi in every tank. (pressure is good) . -
Could it be the circuit board that is in the engine compartment?
I have a new one i was going to put in just because the old one is original to car, but my f.i. harness was new from Bowlsby as was the other harness back there, replaced maybe 2 years ago now.( voltage regulator is fairly new and prior to replacing the board i verified the system was charging good 13.8v. --
Philip W.   I need to fix and replace some bad wiring(melted) near the fuse box   Nov 5 2014, 07:37 AM
bdstone914   I am installing the new Jwwest fuse box and I h...   Nov 5 2014, 09:38 AM
type47   ... to replace and splice in the new piece ... I...   Nov 5 2014, 10:15 AM
Philip W.   Circuit board in place with a few new connectors a...   Nov 5 2014, 09:21 PM
Philip W.   Circuit board in place with a few new connectors ...   Nov 7 2014, 07:24 AM
billh1963   Circuit board in place with a few new connectors ...   Nov 7 2014, 08:35 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 09:56 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 12:53 PM
76-914   12volts at the coil with key on? Do it quickly. Re...   Nov 7 2014, 07:53 AM
Philip W.   12volts at the coil with key on? Do it quickly. R...   Nov 7 2014, 09:59 AM
Dave_Darling   Tape an extra spark plug to a ground, and plug in ...   Nov 7 2014, 10:58 AM
Philip W.   Tape an extra spark plug to a ground, and plug in...   Nov 7 2014, 12:49 PM
Racer Chris   Some of the fuse circuits in the old panel are bri...   Nov 7 2014, 11:14 AM
Philip W.   Some of the fuse circuits in the old panel are br...   Nov 7 2014, 12:42 PM
Racer Chris   do you know which circuits have this? :idea: T...   Nov 7 2014, 01:44 PM
Jeff Bowlsby   Wait. It worked before the fuse panel swap, and ...   Nov 7 2014, 01:06 PM
Tom   You are getting lost in " OMG, what is wrong...   Nov 7 2014, 02:45 PM
Philip W.   So this morning I took Tom's advice and starte...   Nov 8 2014, 10:01 AM
Mike Bellis   Glad you got it running. For the record, the igni...   Nov 8 2014, 10:19 AM
Tom   Glad I was able to get you to stop and think for a...   Nov 8 2014, 02:49 PM
Philip W.   Turns out since tje battery was disconnected I nee...   Nov 8 2014, 10:32 PM
- Lo-Fi Version Time is now: 27th July 2026 - 08:04 AM
