> I need to fix and replace some bad wiring(melted) near the fuse box, **Update 11/6 - installed j-west fuse box * started! woo hoo!
DRPHIL914
post Nov 5 2014, 07:37 AM
Dr. Phil
I am installing the new Jwwest fuse box and
I have a 3" section of wire off the #5 back row fuse that has melted insulation(grey with black stripe)
what is the best way to replace and splice in the new piece and what gauge wire is correct?
ChrisFoley
post Nov 7 2014, 11:14 AM
I am Tangerine Racing
Some of the fuse circuits in the old panel are bridged on the hot side so one hot lead supplies three fuses with power.
The aftermarket panels don't have the bridging and must be added or some circuits won't have power.
Is it possible that the ignition wire from the switch is one of those coming off the panel from a "dead" circuit?
DRPHIL914
post Nov 7 2014, 12:42 PM
Dr. Phil
QUOTE(Racer Chris @ Nov 7 2014, 12:14 PM) *
Chris,
that's interesting, and if that is the case why with the manufacturer of the aftermarket panel not provide that information with the product? that bridging should be in the case of this panel, on the inside? Seems strange to me that bridging wouldnot be built in.
How would i test this? do you know which circuits have this? but also i would be seeing other systems on those fuses not working as well, correct? like my tail lights, signals starter fuel pump etc which all work.
But if lets say 8-9-10 are connected with a common power supply on one side but the bridging is not present but the wires going into 8 test hot 12v, and 9 and 10 are zero that would support your idea. so i need to know which circuits are connected and i can test them to see if power is being supplied. - but first i will check the coil to see if it is getting the 12v when ignition is on like rich suggested, if it is then we should be good(also will do as dave suggested and test the spark on #1 wire with grounded plug)
My initial feeling is that since all the light circuits are working that all the circuits are getting their power. But if we find that not to be the case how the heck do you put in that bridging.
Anyone else here have one of these circuit boards installed? i thought they were plug-n-play!
ChrisFoley
post Nov 7 2014, 01:44 PM
QUOTE(Philip W. @ Nov 7 2014, 01:42 PM) *
Take a look at your old fuse panel to see which circuits are on a common hot lead.
Philip W.   I need to fix and replace some bad wiring(melted) near the fuse box   Nov 5 2014, 07:37 AM
bdstone914   I am installing the new Jwwest fuse box and I h...   Nov 5 2014, 09:38 AM
type47   ... to replace and splice in the new piece ... I...   Nov 5 2014, 10:15 AM
Philip W.   Circuit board in place with a few new connectors a...   Nov 5 2014, 09:21 PM
Philip W.   Circuit board in place with a few new connectors ...   Nov 7 2014, 07:24 AM
billh1963   Circuit board in place with a few new connectors ...   Nov 7 2014, 08:35 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 09:56 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 12:53 PM
76-914   12volts at the coil with key on? Do it quickly. Re...   Nov 7 2014, 07:53 AM
Philip W.   12volts at the coil with key on? Do it quickly. R...   Nov 7 2014, 09:59 AM
Dave_Darling   Tape an extra spark plug to a ground, and plug in ...   Nov 7 2014, 10:58 AM
Philip W.   Tape an extra spark plug to a ground, and plug in...   Nov 7 2014, 12:49 PM
Racer Chris   Some of the fuse circuits in the old panel are bri...   Nov 7 2014, 11:14 AM
Philip W.   Some of the fuse circuits in the old panel are br...   Nov 7 2014, 12:42 PM
Racer Chris   do you know which circuits have this? :idea: T...   Nov 7 2014, 01:44 PM
Jeff Bowlsby   Wait. It worked before the fuse panel swap, and ...   Nov 7 2014, 01:06 PM
Tom   You are getting lost in " OMG, what is wrong...   Nov 7 2014, 02:45 PM
Philip W.   So this morning I took Tom's advice and starte...   Nov 8 2014, 10:01 AM
Mike Bellis   Glad you got it running. For the record, the igni...   Nov 8 2014, 10:19 AM
Tom   Glad I was able to get you to stop and think for a...   Nov 8 2014, 02:49 PM
Philip W.   Turns out since tje battery was disconnected I nee...   Nov 8 2014, 10:32 PM
- Lo-Fi Version Time is now: 27th July 2026 - 08:03 AM
