> I need to fix and replace some bad wiring(melted) near the fuse box, **Update 11/6 - installed j-west fuse box * started! woo hoo!
DRPHIL914
post Nov 5 2014, 07:37 AM
Dr. Phil
I am installing the new Jwwest fuse box and
I have a 3" section of wire off the #5 back row fuse that has melted insulation(grey with black stripe)
what is the best way to replace and splice in the new piece and what gauge wire is correct?
Tom
post Nov 7 2014, 02:45 PM
You are getting lost in " OMG, what is wrong". Stop for a minute and think.
It was running before any work? If yes, then check for voltage at the coil. If there is 12 volts at terminal 15 of the coil with the connector removed, then hook it up temporarily and see what the voltage does. Stays the same or goes down some. Do this quickly or your module will not like it if it is on the closed cycle. If you are getting voltage and fuel, it should start and has nothing to do with your fuse box installation. If it does not start, you have an issue in the engine bay. It could be that your electronic ignition had an issue when the wire melted at the fuse box before your changing in the new one.
Tom
Philip W.   I need to fix and replace some bad wiring(melted) near the fuse box   Nov 5 2014, 07:37 AM
bdstone914   I am installing the new Jwwest fuse box and I h...   Nov 5 2014, 09:38 AM
type47   ... to replace and splice in the new piece ... I...   Nov 5 2014, 10:15 AM
Philip W.   Circuit board in place with a few new connectors a...   Nov 5 2014, 09:21 PM
Philip W.   Circuit board in place with a few new connectors ...   Nov 7 2014, 07:24 AM
billh1963   Circuit board in place with a few new connectors ...   Nov 7 2014, 08:35 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 09:56 AM
Philip W.   Circuit board in place with a few new connectors...   Nov 7 2014, 12:53 PM
76-914   12volts at the coil with key on? Do it quickly. Re...   Nov 7 2014, 07:53 AM
Philip W.   12volts at the coil with key on? Do it quickly. R...   Nov 7 2014, 09:59 AM
Dave_Darling   Tape an extra spark plug to a ground, and plug in ...   Nov 7 2014, 10:58 AM
Philip W.   Tape an extra spark plug to a ground, and plug in...   Nov 7 2014, 12:49 PM
Racer Chris   Some of the fuse circuits in the old panel are bri...   Nov 7 2014, 11:14 AM
Philip W.   Some of the fuse circuits in the old panel are br...   Nov 7 2014, 12:42 PM
Racer Chris   do you know which circuits have this? :idea: T...   Nov 7 2014, 01:44 PM
Jeff Bowlsby   Wait. It worked before the fuse panel swap, and ...   Nov 7 2014, 01:06 PM
Tom   You are getting lost in " OMG, what is wrong...   Nov 7 2014, 02:45 PM
Philip W.   So this morning I took Tom's advice and starte...   Nov 8 2014, 10:01 AM
Mike Bellis   Glad you got it running. For the record, the igni...   Nov 8 2014, 10:19 AM
Tom   Glad I was able to get you to stop and think for a...   Nov 8 2014, 02:49 PM
Philip W.   Turns out since tje battery was disconnected I nee...   Nov 8 2014, 10:32 PM
- Lo-Fi Version Time is now: 27th July 2026 - 09:20 AM
