| Cap'n Krusty |
Nov 6 2014, 01:55 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
In an off the wall reply to a transmission linkage lubrication suggestion I made over on The Bird, I was challenged to supply proof for an assertion I made in an old thread here (!) regarding possible alternator damage from jump starting a car with a dead battery. As the alternator in a car is intended to function primarily as a battery maintainer, NOT a battery charger, Bosch has seen fit to include a warning label or tag with every new or remanufactured alternator they sell. I think it's reasonable to assume they have some valid reason to supply us with that warning, and to extend that wisdom to a dead battery situation leading to the necessity for a jump start.
Some folks have a long memory for things that, for whatever reason, offended them. Because I've been challenged to provide a reason for my earlier statement, which I fully stand behind, I've searched the web for an image of that warning tag. After reading the tag, the person challenging my advice is, of course, free to do exactly as he wishes. Frankly, Scarlett, I don't give a damn. If risking a new alternator, which can be priced at thousands of dollars (yup, and that's in US money!) is what he, or anyone else chooses to do, please be my guest! If this person's engineering department comes up with peer reviewed double blind test results that disprove Bosch's advice, I'd be happy to issue a public apology and review my opinion. Until that happens, I'll err on the side of caution, and do it the right way as I see it. See, Krustiness AND politeness in the same post! Betcha you didn't see THAT coming! The Cap'n |
| stugray |
Nov 7 2014, 03:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I learned this leasson the hard way back in the late 80's with a 911E I had at the time. I was the hero for about 2 minutes until I noticed my alt light on. Never jumped another battery again without first disconnecting mine. This arguement also means: NEVER GIVE SOMEONE A JUMP or you will be violating this rule. While jumping anther car there is a completely different way that altternators get stressed. When the dead car starts running then you have TWO alternators in the system. That means two different voltage regualtors (likely with different setpoitns) fighting each other. The stronger of the two willl win and stress the lesser of the two alts. SO whenever I jump someone, I am always at the ready to unhook the jumpers the SECOND the dead cars starts running. |
| rgalla9146 |
Nov 7 2014, 03:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,943 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I learned this leasson the hard way back in the late 80's with a 911E I had at the time. I was the hero for about 2 minutes until I noticed my alt light on. Never jumped another battery again without first disconnecting mine. This arguement also means: NEVER GIVE SOMEONE A JUMP or you will be violating this rule. While jumping anther car there is a completely different way that altternators get stressed. When the dead car starts running then you have TWO alternators in the system. That means two different voltage regualtors (likely with different setpoitns) fighting each other. The stronger of the two willl win and stress the lesser of the two alts. SO whenever I jump someone, I am always at the ready to unhook the jumpers the SECOND the dead cars starts running. A generator can charge a dead battery. An alternator cannot. Jump start a car with a weak battery ?..... be careful ! Jump start a car with a dead battery ? ..... never ! |
Cap'n Krusty Bosch alternator installation warning tag Nov 6 2014, 01:55 PM
bandjoey I accept your expert opinion always on 914s. Follo... Nov 6 2014, 02:03 PM
Cap'n Krusty No. You would be asking the alternator to do some... Nov 6 2014, 02:16 PM
rdauenhauer Cap'n where are you buying a new OE Bosch Alt ... Nov 6 2014, 02:35 PM
Cap'n Krusty
Cap'n where are you buying a new OE Bosch Alt... Nov 6 2014, 05:22 PM
Tom :agree:
Cap'n Krusty is 100% righ... Nov 6 2014, 07:09 PM
stugray While I agree that charging a dead battery can pul... Nov 6 2014, 07:40 PM
Root_Werks I learned this leasson the hard way back in the la... Nov 7 2014, 02:49 PM
Cap'n Krusty We appear to have the same s*#@storm we had the la... Nov 7 2014, 03:41 PM
stugray
We appear to have the same s*#@storm we had the l... Nov 7 2014, 04:33 PM
Cap'n Krusty Probably written by the legal department ...
The ... Nov 7 2014, 04:53 PM
stugray Just to revisit this discussion:
A Bad alternator... Dec 8 2014, 10:03 AM
colingreene http://www.914world.com/bbs2/uploads_offsite/i0.ky... Dec 9 2014, 12:43 AM
stugray WOW!! A TRS80! I havent sat in front o... Dec 9 2014, 12:48 AM
RobW Don't reverse the terminals either.... Dec 9 2014, 07:36 AM
stugray
Venkm... Dec 9 2014, 12:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 11:10 AM |
