> is there a simple way to test a ignition coil?
rmital
post Nov 10 2014, 10:07 AM
Northeast optimist
got a box full of them. want to use a good one. not interested in buying a new one "if" I have 5 good ones on my shelf.
thanks..... (IMG:style_emoticons/default/flag.gif)
Olympic 914
post Nov 10 2014, 05:01 PM
I believe a coil can test good with a multimeter and still be bad. But if it tests bad, it is. I recently had an issue with the coil on my old Cub Cadet and it tested good but still would not run right, or it would run a little while then quit. So I took my 914 coil and mounted it on there and it worked.
So I just bought a new coil to put on the car.
rmital   is there a simple way to test a ignition coil?   Nov 10 2014, 10:07 AM
Spoke   I assume you mean ignition coils. You could measu...   Nov 10 2014, 10:23 AM
stugray   I have a setup that is more than you are probably ...   Nov 10 2014, 11:12 AM
rmital   @spoke, yes ignition coil...edited the title. than...   Nov 10 2014, 12:05 PM
bandjoey   There is an old thread on this. If no one finds it...   Nov 10 2014, 02:36 PM
rmital   .... Will update this whn I find something. Searc...   Nov 10 2014, 02:44 PM
Racer Chris   Throw it in a pond and if it floats its no good.   Nov 10 2014, 04:10 PM
r_towle   Throw it in a pond and if it floats its no good. ...   Nov 10 2014, 05:59 PM
era vulgaris   Throw it in a pond and if it floats its no good. ...   Nov 10 2014, 06:43 PM
r_towle   Throw it in a pond and if it floats its no good....   Nov 11 2014, 06:59 AM
Olympic 1.7   I believe a coil can test good with a multimeter a...   Nov 10 2014, 05:01 PM
Tom   I believe the DC resistance of the + to - should b...   Nov 10 2014, 08:24 PM
timothy_nd28   :agree:   Nov 10 2014, 08:30 PM
Philip W.   I was just going thru this recently myself and ran...   Nov 10 2014, 09:16 PM
Tom   Just thought I should throw this out there. A...   Nov 11 2014, 02:42 PM
stugray   Maybe Jake or one of the engine builders co...   Nov 11 2014, 08:26 PM
bdstone914   The Haynes manual tests are pretty simple.   Nov 11 2014, 06:28 PM
r_towle   It's a duck   Nov 11 2014, 09:08 PM
- Lo-Fi Version Time is now: 13th March 2026 - 11:58 PM
