| trojanhorsepower |
Nov 9 2014, 07:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Search is not my friend. Has there been a long drawn out thread about SPI epoxy primer? If so please point me to it. I don't want to stir the pot, just looking for information. I have found a lot about using it on their forum, but it is a little cult like over there. Just hoping to get a range of opinions.
| trojanhorsepower |
Nov 11 2014, 09:30 AM
I see that Shopline lists body filler as a compatible surface, but is that under, on top of or both?
trojanhorsepower SPI Nov 9 2014, 07:05 PM
dlee6204 I've used their epoxy stuff with overall good ... Nov 9 2014, 07:15 PM
trojanhorsepower Thanks Doug,
I will definitely try it out when the... Nov 9 2014, 07:27 PM
scotty b From personal experience. I do not like " off... Nov 9 2014, 07:34 PM
trojanhorsepower Thanks Scotty,
Do you wash the Ospho, or just let ... Nov 9 2014, 08:11 PM
scotty b
Thanks Scotty,
Do you wash the Ospho, or just let... Nov 9 2014, 08:45 PM
roblav1 PPG DP epoxies are the way to go. Nov 9 2014, 08:32 PM
trojanhorsepower OK. So would you put ospho on all metal or just o... Nov 9 2014, 09:00 PM
scotty b I normally just put it over old to make certain an... Nov 9 2014, 09:08 PM
scotty b
I see that Shopline lists body filler as a compat... Nov 11 2014, 12:43 PM
trojanhorsepower So is it safe to just use all the products in the ... Nov 28 2014, 08:43 PM
Rob-O I used PPG's DP products, great stuff.
As f... Nov 28 2014, 09:04 PM
trojanhorsepower http://www.ebay.com/itm/New-DeVILBISS-Fini...t-/39... Nov 29 2014, 08:31 PM
scotty b That Devillbiss is a good all around setup. Much b... Nov 29 2014, 09:19 PM
trojanhorsepower Thanks Guys!
Sounds like I have a plan. Nov 30 2014, 04:48 PM
trojanhorsepower After looking more closely at what my compressor c... Apr 22 2015, 07:38 PM
bulitt Last time I tried to buy shop line the distributor... Apr 22 2015, 08:15 PM
cary Same with my PPG shop. Deltron and Omni only.
So I... Apr 22 2015, 08:29 PM
trojanhorsepower I checked at napa when I started this thread and t... Apr 23 2015, 07:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:42 AM |
