Motor Assembly |
Motor Assembly |
Bulldog9 |
Nov 10 2014, 09:01 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The time has come to start assembling the motor. I painted the tins over the weekend and, all that is left to paint is the fan assembly. 2 years of strip, clean condition paint......... I am done...
I will be cleaning up the garage over the Holiday and weekend and start assembling the motor this weekend or next week. Its been a long 2 years gathering all this, and is hard to believe it is almost time. I will be checking in and asking for advice on the engine build in this thread as my motor is nearly identical to the 914. I have TWO questions at this point, 1. I seem to have misplaced the new recommended list of engine case and sealants. Does anyone have this? 2. It is time to decide if I will use the Steel backed silverline (made in Mexico) bearings, or the non steel backed Mahle (looks to be Brazil). Yeah, I know there are a million opinions on this, and I plan to go with the steel backed at this point, but figured I'd ask. Appreciate any advice here, is my first Type 4 build. THANKS! |
Dave_Darling |
Nov 11 2014, 12:28 AM
For a Web cam, stick with Web lifters. I've never thought the idea of a hole in the wear surface of a lifter was that good an idea anyway (the "lube a lobe", as I understand it, has an oil hole on the face of the lifter). You really want to make sure the cam and lifters are compatible with each other.
--DD |
McMark |
Nov 11 2014, 01:31 PM
For a Web cam, stick with Web lifters. I've never thought the idea of a hole in the wear surface of a lifter was that good an idea anyway (the "lube a lobe", as I understand it, has an oil hole on the face of the lifter). You really want to make sure the cam and lifters are compatible with each other. --DD This is one of the anxiety-decisions of building a motor. I think there are a lot of motors out there with Lube-A-Lobe lifters on WebCams. I like the idea of the lubing hole. But then again, there are a lot more WebCams on WebCam lifters out there and the extra lube may be irrelevant. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:54 PM |
