| rmital |
Nov 10 2014, 10:07 AM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
got a box full of them. want to use a good one. not interested in buying a new one "if" I have 5 good ones on my shelf.
thanks..... (IMG:style_emoticons/default/flag.gif) |
| Tom |
Nov 11 2014, 02:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Just thought I should throw this out there.
A simple DC resistance test will only test the primary and secondary windings under not running conditions. Coils will and do break down under heat and electrical load. Many folks get really discouraged when testing ignition systems on cars that won't start or run right and when doing the spark plug outside the engine test get a spark. Well there are sparks and there are SPARKS. A strong blue spark is preferred. I remember back in about 1970 taking a gas engine course and during the ignition part the instructor showed us an engine that had what seemed to be a good spark. Would not start! The class went thru the entire electrical troubleshooting procedure to try to get the engine to fire. Finally after trading out the coil for a new one, it fired and ran fine. The old coil was putting out a spark that was slightly weak. I wish I could remember why the weaker coil produced what to us looked like a good spark but would not fire under compression. I am sure he explained it, I just can't remember. (IMG:style_emoticons/default/sad.gif) A few years later while playing with RD-350's, I had Don Vesco's shop port and polish the cylinders/pistons, and machine the head for increased compression. The mechanic that performed the work also told me I would have ignition issues if I did not improve the ignition system. When I asked what to do, he said go to K-mart and buy a $6.00 K-Mart coil and install it and widen the plug gap by 0.010 inches. Well I did what he said and it fired just fine. Boy that bike was fast for it's time!!! Maybe Jake or one of the engine builders could tell us more on why coils break down under higher compression. I have heard of lots of guys that had a great running car only to rebuild it with higher compression pistons and then have issues with the stock ignition system. Tom |
rmital is there a simple way to test a ignition coil? Nov 10 2014, 10:07 AM
Spoke I assume you mean ignition coils.
You could measu... Nov 10 2014, 10:23 AM
stugray I have a setup that is more than you are probably ... Nov 10 2014, 11:12 AM
rmital @spoke, yes ignition coil...edited the title. than... Nov 10 2014, 12:05 PM
bandjoey There is an old thread on this. If no one finds it... Nov 10 2014, 02:36 PM
rmital
Will update this whn I find something. Searc... Nov 10 2014, 02:44 PM
Racer Chris Throw it in a pond and if it floats its no good. Nov 10 2014, 04:10 PM
r_towle
... Nov 10 2014, 05:59 PM
era vulgaris
... Nov 10 2014, 06:43 PM
r_towle
Throw it in a pond and if it floats its no good.... Nov 11 2014, 06:59 AM
Olympic 1.7 I believe a coil can test good with a multimeter a... Nov 10 2014, 05:01 PM
Tom I believe the DC resistance of the + to - should b... Nov 10 2014, 08:24 PM
timothy_nd28 :agree: Nov 10 2014, 08:30 PM
Philip W. I was just going thru this recently myself and ran... Nov 10 2014, 09:16 PM
stugray
Maybe Jake or one of the engine builders co... Nov 11 2014, 08:26 PM
bdstone914 The Haynes manual tests are pretty simple. Nov 11 2014, 06:28 PM
r_towle It's a duck Nov 11 2014, 09:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:00 AM |
