> Another 'bucking' question….
Larmo63
post Nov 13 2014, 07:30 PM
After the third set of old heat exchangers on my '73 1.7 FI, I finally buttoned up exhaust leaks and now the car has started bucking/hesitation. All new ignition parts, timing, TPS exchanged with a new one, no difference. No known vacuum leaks. I can drive the car and it has power, but I have to drive "around" the hesitations. Fuel pump was replaced too. I'd like it to run better while I finish the 2056 carb engine. Ideas? (IMG:style_emoticons/default/headbang.gif)
r_towle
post Nov 13 2014, 09:09 PM
Custom Member
Describe the bucking in more detail....
Accel or decel?
High RPM or low?
Cruising or pushing it?
Rich
Larmo63   Another 'bucking' question….   Nov 13 2014, 07:30 PM
krazykonrad   My guess is the MPS diaphragm has worn out. That c...   Nov 13 2014, 08:28 PM
mepstein   Check all grounds and electrical connections aroun...   Nov 13 2014, 08:33 PM
914_teener   After the third set of old heat exchangers on my ...   Nov 13 2014, 08:36 PM
r_towle   Describe the bucking in more detail.... Accel or ...   Nov 13 2014, 09:09 PM
Larmo63   Mostly during acceleration. It doesn't want to...   Nov 14 2014, 09:38 AM
rjames   Check all fuel delivery items from the filter to t...   Nov 14 2014, 11:12 AM
Larmo63   We only worked on sealing up the intake system. Ne...   Nov 14 2014, 06:31 PM
Jasfsmith   We only worked on sealing up the intake system. N...   Nov 17 2014, 08:59 AM
Philip W.   We only worked on sealing up the intake system. N...   Nov 19 2014, 07:04 AM
Gcotton92203   I had that problem twice. I found a leak at the va...   Nov 14 2014, 06:43 PM
r_towle   Sounds lean. Check injector seals? Not visible, bu...   Nov 14 2014, 06:59 PM
57lincolnman   After the third set of old heat exchangers on my ...   Nov 14 2014, 09:03 PM
larss   Did you change to a new TPS or only to a new TPS c...   Nov 15 2014, 12:27 AM
dknechtly   Since it's on acceleration, check that your va...   Nov 17 2014, 08:43 AM
colingreene   quote name='dknechtly' date='Nov 17 20...   Nov 19 2014, 03:38 AM
Philip W.   my last TPS was a replacement board and brand new,...   Nov 19 2014, 06:47 AM
- Lo-Fi Version Time is now: 8th December 2025 - 12:27 AM
