> Another 'bucking' question….
Larmo63
post Nov 13 2014, 07:30 PM
After the third set of old heat exchangers on my '73 1.7 FI, I finally buttoned up exhaust leaks and now the car has started bucking/hesitation. All new ignition parts, timing, TPS exchanged with a new one, no difference. No known vacuum leaks. I can drive the car and it has power, but I have to drive "around" the hesitations. Fuel pump was replaced too. I'd like it to run better while I finish the 2056 carb engine. Ideas? (IMG:style_emoticons/default/headbang.gif)
rjames
post Nov 14 2014, 11:12 AM
I'm made of metal
Check all fuel delivery items from the filter to the injectors.
What changes did you make before the bucking started?
Larmo63   Another 'bucking' question….   Nov 13 2014, 07:30 PM
krazykonrad   My guess is the MPS diaphragm has worn out. That c...   Nov 13 2014, 08:28 PM
mepstein   Check all grounds and electrical connections aroun...   Nov 13 2014, 08:33 PM
914_teener   After the third set of old heat exchangers on my ...   Nov 13 2014, 08:36 PM
r_towle   Describe the bucking in more detail.... Accel or ...   Nov 13 2014, 09:09 PM
Larmo63   Mostly during acceleration. It doesn't want to...   Nov 14 2014, 09:38 AM
rjames   Check all fuel delivery items from the filter to t...   Nov 14 2014, 11:12 AM
Larmo63   We only worked on sealing up the intake system. Ne...   Nov 14 2014, 06:31 PM
Jasfsmith   We only worked on sealing up the intake system. N...   Nov 17 2014, 08:59 AM
Philip W.   We only worked on sealing up the intake system. N...   Nov 19 2014, 07:04 AM
Gcotton92203   I had that problem twice. I found a leak at the va...   Nov 14 2014, 06:43 PM
r_towle   Sounds lean. Check injector seals? Not visible, bu...   Nov 14 2014, 06:59 PM
57lincolnman   After the third set of old heat exchangers on my ...   Nov 14 2014, 09:03 PM
larss   Did you change to a new TPS or only to a new TPS c...   Nov 15 2014, 12:27 AM
dknechtly   Since it's on acceleration, check that your va...   Nov 17 2014, 08:43 AM
colingreene   quote name='dknechtly' date='Nov 17 20...   Nov 19 2014, 03:38 AM
Philip W.   my last TPS was a replacement board and brand new,...   Nov 19 2014, 06:47 AM
- Lo-Fi Version Time is now: 8th December 2025 - 12:26 AM
