> Battery Drain, Voltage Regulator
Rhodes71/914
post Aug 25 2004, 10:29 AM
Glacier
I have asked this question before with no response but I am trying again. Hopefully there is at least one person out there that can give me an answer. (IMG:style_emoticons/default/biggrin.gif)
I have a new battery. When I leave it hooked up to the car overnight it is dead the next day. Key is off. Nothing is on that I can tell.
What I did notice is that The voltage regulator is warm to the touch. This is without the engine running.
Bad voltage regulator or another problem.
ArtechnikA
post Aug 25 2004, 03:48 PM
rich herzog
Freezing14's advice is good in general but i suspect it won't help in your case...
it sounds to me like you have a bad (or very weak) diode in the alternator.
you might be able to see this with a scope on the charging circuit (i'd expect to see a lot of ripple) or there may be another charging system test that can confirm it.
there shouldn't be any current through the alternator with the key off. if there is, that could confirm it. worry - i don't have THE definitive test to prove this - but your symptoms match bad alternator ...
- Lo-Fi Version Time is now: 6th July 2025 - 06:31 PM
