> 3.0/ 930 Engine-A few failed head studs….. Pics!, A little on the exceptional side...…
Jake Raby
post Nov 18 2014, 09:56 PM
Engine Surgeon
So, I am building a 3 liter for a very low serial # first year 930. The car has been sitting for many years and its been a challenge thus far to deal with.
I knew I was in for a surprise when I stripped the ancillaries off and rolled the engine upside down on the stand and a couple of broken head studs, with their nuts fell onto the ground..
I never dreamed that EVERY head stud except one, on each side of the engine would have been broken! These did not break during disassembly! i only had to put a wrench on one nut on each side of the engine!
We've all seen these break like mad, but I've never seen this many broken on one engine. The real crazy thing is, it appears the only reason they stopped driving it was due to chain rail failure that made the bank 2 chain drag loudly inside the chain housing.
The heads were sealed tightly to the cylinders and only one of them showed signs of any combustion leakage.
The owner wanted something special, so they sent it this way, so I'll see what I can cook up :-)
post Nov 18 2014, 10:12 PM
They all broke due to rust on the head nuts an studs..must have been sitting outside. Look at the tins too.
Jake Raby
post Nov 18 2014, 10:41 PM
Engine Surgeon
QUOTE(396 @ Nov 18 2014, 08:12 PM) *
These rusted after they were broken. The rust did not effect them structurally. Where they were laying in the engine they could have never found their way there unless the engine was operated this way.
These engines were horrible about breaking studs, and this was the 28th turbo off the assembly line (documented), so its a very early example.
The engine also has two bent rods, so it is my bet that someone turned the boost up and created this issue for an already weaker set up.
I split the case today and the internals are otherwise beautiful.. Its going to be a fun one to resurrect, especially considering who owns it. She's a pretty cool chick.
- Lo-Fi Version Time is now: 16th April 2026 - 05:36 PM
