| DavidSweden |
Nov 19 2014, 01:51 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip Cap“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
| Cap'n Krusty |
Nov 19 2014, 10:10 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
That's it. Applies ONLY to certain VW Bus engines, NOT 914s.
The Cap'n |
| DBCooper |
Nov 20 2014, 01:39 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
That's it. Applies ONLY to certain VW Bus engines, NOT 914s. The Cap'n Do something for me, Cap'n. Look at the date on that bulletin. Manufacturers are required to support their products for ten years, meaning Volkswagen had an obligation to issue that bulletin while Porsche, who had stopped selling cars with those engines more than ten years previously, had no obligation. But they're the same engine if installed in a Volkswagen or a Porsche, aren't they? So why would VW's advice be any different if their engines were installed in Porsche cars or VW's? The problem VW was addressing was the tendency of their head gaskets to fail and burn through the gaskets, usually but not always on high mileage engines. Aircooled engines run hot and the VW design sandwiches an iron cylinder between an aluminum case and an aluminum head, where the heat cycles from normal use repeatedly compress the head gasket, eventually consuming all its flexibility and ability to seal. Combustion will eventually erode through a head gasket, and usually take the head with it. You may have never had the problem, I don't know, but Volkswagen did, and they had it a lot. They didn't issue that bulletin frivolously, defective products are a very hard and expensive thing for any car company to admit. It's not an imagined problem, there was a good reason. |
| Cap'n Krusty |
Nov 20 2014, 10:31 AM
That's it. Applies ONLY to certain VW Bus engines, NOT 914s. The Cap'n Do something for me, Cap'n. Look at the date on that bulletin. Manufacturers are required to support their products for ten years, meaning Volkswagen had an obligation to issue that bulletin while Porsche, who had stopped selling cars with those engines more than ten years previously, had no obligation. But they're the same engine if installed in a Volkswagen or a Porsche, aren't they? So why would VW's advice be any different if their engines were installed in Porsche cars or VW's? The problem VW was addressing was the tendency of their head gaskets to fail and burn through the gaskets, usually but not always on high mileage engines. Aircooled engines run hot and the VW design sandwiches an iron cylinder between an aluminum case and an aluminum head, where the heat cycles from normal use repeatedly compress the head gasket, eventually consuming all its flexibility and ability to seal. Combustion will eventually erode through a head gasket, and usually take the head with it. You may have never had the problem, I don't know, but Volkswagen did, and they had it a lot. They didn't issue that bulletin frivolously, defective products are a very hard and expensive thing for any car company to admit. It's not an imagined problem, there was a good reason. "But they're the same engine if installed in a Volkswagen or a Porsche, aren't they? " No, they're not. The head design on the 2.0 914 is substantially different from that of the Bus. "Supporting" the engines means supplying parts, NOT fixing them or addressing problems beyond the written warranty period. You see Porsche supplying a "fix" for the smogged up 2.7 ten years down the road? Or, beyond defective valve guide replacement, even during the warranty period? I think not. You'll note the changes under discussion affect only certain original and factory remanufactured engines, hence the statement: "These changes effect Engine codes: GD, GE, CV." Note the elimination of head gaskets goes along with piston lubrication, increased piston to cylinder clearances, and replacement of the paper base gaskets. I know Jake doesn't use head gaskets, and we've had discussions to that effect. He does a lot more engines than I, and he doesn't just "rebuild" them. EVERY case is selected and remanufactured according to strict guidelines he has established for his work. Few, if any, are what you would call "routine rebuilds". Most, in fact, are what you could call "modified for performance purposes". Some cost a lot more than the cars they're going into. If you're willing to put the kind of basic prep work into your engine that Jake does, the absence of head gaskets is probably not going to be a bad thing. How many folks here have the cases checked for warpage, and corrected both at the bore AND the deck? People on this forum complain about the cost of a rebuild, and they don't even do a proper "remanufacture". Most just do the minimum and forget it until something fails prematurely. Not so Jake, and not so me. The Cap'n |
DavidSweden Head gasket Nov 19 2014, 01:51 PM
r_towle that is the basic explaination.
I would suggest y... Nov 19 2014, 02:03 PM
Elliot Cannon FAT Performance uses head gaskets. European Motor... Nov 19 2014, 07:20 PM
r_towle
FAT Performance uses head gaskets. European Moto... Nov 19 2014, 07:56 PM
Elliot Cannon
FAT Performance uses head gaskets. European Mot... Nov 20 2014, 12:38 PM
brp986s RTV = room temperature vulcanizing - :poke: :pok... Nov 20 2014, 02:36 PM
r_towle
[quote name='r_towle' post='2112498' date='Nov 19... Nov 20 2014, 06:03 PM
Elliot Cannon
[quote name='r_towle' post='2112498' date='Nov 1... Nov 20 2014, 07:11 PM
ThePaintedMan :stromberg: Nov 19 2014, 08:45 PM
Mark Henry I don't use them, new AMC heads have a big red... Nov 19 2014, 09:57 PM
DBCooper The 2.0 heads have a different combustion chamber,... Nov 20 2014, 11:09 AM
ClayPerrine
That's it. Applies ONLY to certain VW Bus en... Nov 20 2014, 05:46 AM
Jake Raby I haven't built a single engine with head gask... Nov 20 2014, 12:23 AM
Mark Henry I haven't built a engine with head gaskets in ... Nov 20 2014, 08:15 AM
r_towle
I haven't built a engine with head gaskets in... Nov 20 2014, 09:23 AM
Highland When I worked on my motor I searched all the threa... Nov 20 2014, 09:56 AM
DBCooper The Porsche six cylinder engines aren't really... Nov 20 2014, 10:19 AM
Jake Raby
The Porsche six cylinder engines aren't reall... Nov 20 2014, 10:25 AM
DBCooper
The Porsche six cylinder engines aren't real... Nov 20 2014, 10:29 AM
stugray
I haven't built a engine with head gaskets in... Nov 20 2014, 10:30 AM
stugray
[b]RTV is NOT an acronym. :poke: FAT Performan... Nov 20 2014, 12:50 PM
ThePaintedMan I thought he was talking about POO. Not an acronym... Nov 20 2014, 01:49 PM
StratPlayer I used head gaskets on my engine build.. No proble... Nov 20 2014, 01:57 PM
dknechtly I usually do not use head gaskets. I have the head... Nov 20 2014, 04:27 PM
r_towle :alfred: Nov 20 2014, 07:31 PM
ThePaintedMan Love grammar debates. Ellyutt is right. RTV is tec... Nov 20 2014, 08:11 PM
r_towle
Love grammar debates. Ellyutt is right. RTV is te... Nov 20 2014, 08:51 PM
colingreene European told me not to use head gaskets. idk man. Nov 20 2014, 08:18 PM
ThePaintedMan :rotfl: I like. Nov 20 2014, 09:01 PM
Mark Henry Of course this whole argument is moot if using 96m... Nov 20 2014, 09:03 PM
ClayPerrine Just a point I would like to make.....
Betty is ... Nov 20 2014, 09:48 PM
DBCooper
There is nothing in any Porsche manual or bulleti... Nov 23 2014, 11:08 AM
Cap'n Krusty The point that everyone here seems to have missed ... Nov 23 2014, 05:02 PM
colingreene
Of course this whole argument is moot if using 96... Nov 23 2014, 05:06 PM
Cap'n Krusty
Of course this whole argument is moot if using 9... Nov 23 2014, 06:57 PM
colingreene Right, thats why i said WTF. Nov 23 2014, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:14 PM |
