| DavidSweden |
Nov 19 2014, 01:51 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am currently rebuilding engine. In order not to tire everyone with a lot of newbie questions I have been searching the forum (thanks for the tip Cap“n).
There has been a lot of debate about using or not using head gaskets. Is this the VW tech bulletin which has been referred to in some of the post recommending not to use the head gaskets? VW Tech bulletin head gasket David |
| Elliot Cannon |
Nov 19 2014, 07:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif)
| r_towle |
Nov 19 2014, 07:56 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif) You use lots of things that maybe only you would use (IMG:style_emoticons/default/biggrin.gif) A three letter acronym of a certain substance that smears all over the place..... Things like that .... |
| Elliot Cannon |
Nov 20 2014, 12:38 PM
FAT Performance uses head gaskets. European Motorworks uses head gaskets. As it turns out, so do I. (IMG:style_emoticons/default/biggrin.gif) You use lots of things that maybe only you would use (IMG:style_emoticons/default/biggrin.gif) A three letter acronym of a certain substance that smears all over the place..... Things like that .... RTV is NOT an acronym. (IMG:style_emoticons/default/poke.gif) FAT Performance uses it, European Motorworks uses it and as it turns out, so do I. (IMG:style_emoticons/default/av-943.gif) |
| brp986s |
Nov 20 2014, 02:36 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
RTV = room temperature vulcanizing - (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif)
DavidSweden Head gasket Nov 19 2014, 01:51 PM
r_towle that is the basic explaination.
I would suggest y... Nov 19 2014, 02:03 PM
r_towle
[quote name='r_towle' post='2112498' date='Nov 19... Nov 20 2014, 06:03 PM
Elliot Cannon
[quote name='r_towle' post='2112498' date='Nov 1... Nov 20 2014, 07:11 PM
ThePaintedMan :stromberg: Nov 19 2014, 08:45 PM
Mark Henry I don't use them, new AMC heads have a big red... Nov 19 2014, 09:57 PM
Cap'n Krusty That's it. Applies ONLY to certain VW Bus eng... Nov 19 2014, 10:10 PM
DBCooper
That's it. Applies ONLY to certain VW Bus en... Nov 20 2014, 01:39 AM
Cap'n Krusty
That's it. Applies ONLY to certain VW Bus e... Nov 20 2014, 10:31 AM
DBCooper The 2.0 heads have a different combustion chamber,... Nov 20 2014, 11:09 AM
ClayPerrine
That's it. Applies ONLY to certain VW Bus en... Nov 20 2014, 05:46 AM
Jake Raby I haven't built a single engine with head gask... Nov 20 2014, 12:23 AM
Mark Henry I haven't built a engine with head gaskets in ... Nov 20 2014, 08:15 AM
r_towle
I haven't built a engine with head gaskets in... Nov 20 2014, 09:23 AM
Highland When I worked on my motor I searched all the threa... Nov 20 2014, 09:56 AM
DBCooper The Porsche six cylinder engines aren't really... Nov 20 2014, 10:19 AM
Jake Raby
The Porsche six cylinder engines aren't reall... Nov 20 2014, 10:25 AM
DBCooper
The Porsche six cylinder engines aren't real... Nov 20 2014, 10:29 AM
stugray
I haven't built a engine with head gaskets in... Nov 20 2014, 10:30 AM
stugray
[b]RTV is NOT an acronym. :poke: FAT Performan... Nov 20 2014, 12:50 PM
ThePaintedMan I thought he was talking about POO. Not an acronym... Nov 20 2014, 01:49 PM
StratPlayer I used head gaskets on my engine build.. No proble... Nov 20 2014, 01:57 PM
dknechtly I usually do not use head gaskets. I have the head... Nov 20 2014, 04:27 PM
r_towle :alfred: Nov 20 2014, 07:31 PM
ThePaintedMan Love grammar debates. Ellyutt is right. RTV is tec... Nov 20 2014, 08:11 PM
r_towle
Love grammar debates. Ellyutt is right. RTV is te... Nov 20 2014, 08:51 PM
colingreene European told me not to use head gaskets. idk man. Nov 20 2014, 08:18 PM
ThePaintedMan :rotfl: I like. Nov 20 2014, 09:01 PM
Mark Henry Of course this whole argument is moot if using 96m... Nov 20 2014, 09:03 PM
ClayPerrine Just a point I would like to make.....
Betty is ... Nov 20 2014, 09:48 PM
DBCooper
There is nothing in any Porsche manual or bulleti... Nov 23 2014, 11:08 AM
Cap'n Krusty The point that everyone here seems to have missed ... Nov 23 2014, 05:02 PM
colingreene
Of course this whole argument is moot if using 96... Nov 23 2014, 05:06 PM
Cap'n Krusty
Of course this whole argument is moot if using 9... Nov 23 2014, 06:57 PM
colingreene Right, thats why i said WTF. Nov 23 2014, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:42 PM |
