Intercoolers?, Where are you turbo dudes putting one? |
zach914v8 |
Nov 19 2014, 09:16 PM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
I'm in the beginning steps of redoing my car. I have a boxster 6 speed and adapter plate(s)and flywheel and flex plate.. I was considering a built ls1, but now I'm leaning towards a turbo 4.8.
I know that there are probably not a lot of turbo 914's out there, but the ones that are, where did those guys mount their intercoolers? I don't really want to do the water to air thing. If I decide to do twins, I thought about scoops on the quarter panels, and one small intercooler on each side. Or If I do a single turbo, 1 large intercooler in the rear trunk with a hole cut into the lid, then another hole out of the rear of the car between the tail lights. But I'm looking for ideas/ inspiration. |
iamchappy |
Nov 22 2014, 02:56 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
My 1080 CFM intercooler works just fine.
Mike Bellis |
Nov 22 2014, 06:16 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
iamchappy |
Nov 22 2014, 09:34 PM
My 1080 CFM intercooler works just fine. What are your intake temps at the throttle body? Dont know other than they are much cooler (warm) after ic than (hot) before ic My fans pull air through it really good, and the air scoop in the spoiler helps get the outside air to it. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:13 PM |
